Сообщений 391 страница 420 из 994
391
Elodar
Так, на сколько я соображаю, то прицепы все одинаковы, даже на ЕТС те же самые.
А если какой сторонний, то прописывается так же, как и в ГТС
Может мне все-таки кто-нибудь ответит на мой вопрос:
******** : log created on : Monday September 12 2011 @ 18:55:23
18:55:23 : [sys] running on x86 / Windows XP (version 5.1) / Service Pack 3
18:55:23 : [sys] DirectX version : 4.09.00.0904
18:55:23 : [cpu] GenuineIntel [Intel(R) Core(TM)2 Duo CPU     E8500  @ 3.16GHz] at ~3166MHz.
18:55:23 : [cpu] Features utilized: fpu cmov mmx sse sse2.
18:55:23 : [sys] using QPC / TSC timer (thread affinity: 1), frequency 3166750000Hz
18:55:23 : [mem] physical memory detected (2097151K/2097151K)
18:55:23 : [mem] virtual memory detected (2097024K/2063244K)
18:55:23 : [mem] Trying to allocate memory pool (409600K)
18:55:23 : [zipfs] base.scs: mounted ok, 12698 entries [0x943d26d6]
18:55:23 : [ufs] registered symlink from /custom_build/de_de to /
18:55:23 : [zipfs] <mem-addr-file>: mounted ok, 8 entries [0x359abc2e]
18:55:23 : [ufs] Home directory: 'C:/Documents and Settings/Admin/Мои документы/German Truck Simulator'.
18:55:23 : Mounting extra package: C:/Documents and Settings/Admin/Мои документы/German Truck Simulator/mod/RUSGTS.scs
18:55:23 : [zipfs] RUSGTS.scs: mounted ok, 80 entries [0xa1b47bfb]
18:55:23 : Mounting extra package: C:/Documents and Settings/Admin/Мои документы/German Truck Simulator/mod/XMapzeug.scs
18:55:23 : [zipfs] XMapzeug.scs: mounted ok, 8587 entries [0xebbe5a0b]
18:55:23 : Mounting extra package: C:/Documents and Settings/Admin/Мои документы/German Truck Simulator/mod/XSchildgedons.scs
18:55:23 : Mount failed: C:/Documents and Settings/Admin/Мои документы/German Truck Simulator/mod/XSchildgedons.scs
18:55:23 : Mounting extra package: C:/Documents and Settings/Admin/Мои документы/German Truck Simulator/mod/XXReal-Speed.scs
18:55:23 : [zipfs] XXReal-Speed.scs: mounted ok, 23 entries [0x7ca653f3]
18:55:23 : Mounting extra package: C:/Documents and Settings/Admin/Мои документы/German Truck Simulator/mod/zzzzzzzGTS Getriebe Reiskorn Map_Bremse beta 0.4.scs
18:55:23 : [zipfs] zzzzzzzGTS Getriebe Reiskorn Map_Bremse beta 0.4.scs: mounted ok, 9 entries [0xd6dd5ae]
18:55:23 : Mounting extra package: C:/Documents and Settings/Admin/Мои документы/German Truck Simulator/mod/zzzzzzzzzzzzzzzzzFIX-RKE1.11.scs
18:55:23 : [zipfs] zzzzzzzzzzzzzzzzzFIX-RKE1.11.scs: mounted ok, 2 entries [0x11f9b3c7]
18:55:23 : exec /home/config.cfg
18:55:23 : [sys] Executing /home/config.cfg ...
18:55:23 : German Truck Simulator init ver.1.00 (rev. 25903)
18:55:23 : [gl] ICD OpenGL driver detected.
18:55:23 : [gl] driver: GeForce 9800 GT/PCI/SSE2
18:55:23 : [gl] vendor: NVIDIA Corporation
18:55:23 : [gl] version: 3.0.0
18:55:23 : [gl] GL_max_texture_size: 8192
18:55:23 : [gl] taking advantage of 'GL_multitexture'
18:55:23 : [gl] Sampler count: 4
18:55:23 : [gl] taking advantage of 'GL_ARB_fragment_program'
18:55:23 : [gl] taking advantage of 'GL_texture_mirrored_repeat'
18:55:23 : [gl] taking advantage of 'GL_texture_border_clamp'
18:55:23 : [gl] taking advantage of 'GL_texture_compression'
18:55:23 : [gl] taking advantage of 'GL_EXT_texture_compression_s3tc'
18:55:23 : [gl] taking advantage of 'GL_texture_cube_map'
18:55:23 : [gl] taking advantage of 'GL_texture_env_crossbar'
18:55:23 : [gl] taking advantage of 'GL_texture_env_combine'
18:55:23 : [gl] taking advantage of 'GL_ARB_texture_rectangle'
18:55:23 : [gl] taking advantage of 'GL_transpose_matrix'
18:55:23 : [gl] taking advantage of 'GL_vertex_buffer_object'
18:55:23 : [gl] taking advantage of 'GL_ARB_vertex_program'
18:55:23 : [gl] Vertex attribute count: 16
18:55:23 : [gl] taking advantage of 'GL_shader_objects'
18:55:23 : [gl] taking advantage of 'GL_vertex_shader'
18:55:23 : [gl] taking advantage of 'GL_fragment_shader'
18:55:23 : [gl] taking advantage of 'GL_draw_buffers'
18:55:23 : [gl] taking advantage of 'GL_blend_color'
18:55:23 : [gl] taking advantage of 'GL_EXT_compiled_vertex_array'
18:55:23 : [gl] taking advantage of 'GL_draw_range_elements'
18:55:23 : [gl] taking advantage of 'GL_rescale_normal'
18:55:23 : [gl] taking advantage of 'GL_secondary_color'
18:55:23 : [gl] taking advantage of 'GL_separate_spcular_color'
18:55:23 : [gl] taking advantage of 'GL_texture3D'
18:55:23 : [gl] taking advantage of 'GL_texture_edge_clamp'
18:55:23 : [gl] taking advantage of 'GL_texture_env_add'
18:55:23 : [gl] taking advantage of 'GL_EXT_texture_filter_anisotropic'
18:55:23 : [gl] Max anisotropy factor: 16
18:55:23 : [gl] taking advantage of 'GL_NV_register_combiners'
18:55:23 : [gl] taking advantage of 'GL_NV_register_combiners2'
18:55:23 : [gl] taking advantage of 'GL_NV_texture_env_combine4'
18:55:23 : [gl] taking advantage of 'GL_NV_texture_shader'
18:55:23 : [gl] taking advantage of 'GL_NV_texture_shader2'
18:55:23 : [gl] taking advantage of 'GL_NV_texture_shader3'
18:55:23 : [gl] taking advantage of 'GL_NV_fragment_program'
18:55:23 : [gl] taking advantage of 'GL_NV_fragment_program_option'
18:55:23 : [gl] taking advantage of 'GL_NV_fragment_program2'
18:55:23 : [gl] taking advantage of 'GL_NV_vertex_program2'
18:55:23 : [gl] taking advantage of 'GL_NV_vertex_program2_option'
18:55:23 : [gl] taking advantage of 'GL_NV_vertex_program3'
18:55:23 : [gl] taking advantage of 'GL_generate_mipmap'
18:55:23 : [gl] taking advantage of 'GL_framebuffer_object'
18:55:23 : [gl] taking advantage of 'WGL_ARB_extensions_string'
18:55:23 : [gl] WGL extensions: WGL_ARB_buffer_region WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_pixel_format_float WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_ARB_create_context WGL_EXT_extensions_string WGL_EXT_framebuffer_sRGB WGL_EXT_pixel_format_packed_float WGL_EXT_swap_control WGL_NV_float_buffer WGL_NV_multisample_coverage WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle
18:55:23 : [gl] taking advantage of 'WGL_EXT_swap_control'
18:55:23 : [gl] taking advantage of 'WGL_ARB_pixel_format'
18:55:23 : [gl] taking advantage of 'GL_ARB_multisample'
18:55:24 : [gl] Detected support for 16x anti-aliasing.
18:55:25 : [gl] Detected support for 8x anti-aliasing.
18:55:25 : [gl] Detected support for 4x anti-aliasing.
18:55:25 : [gl] Detected support for 2x anti-aliasing.
18:55:25 : [gl-quirk] Enabling workaround for alpha-testing overoptimization.
18:55:25 : Rendering path available: GL1X
18:55:25 : Rendering path available: ARB1
18:55:25 : Rendering path available: NV1X
18:55:25 : Rendering path available: NV2X
18:55:25 : Rendering path available: NV3X
18:55:25 : Rendering path available: NV4X
18:55:25 : Rendering path available: ARB2
18:55:25 : Rendering path available: GL2X
18:55:25 : [dx9] Direct3D9 detected.
18:55:25 : [dx9] Number of adapters found: 1
18:55:25 : [dx9] Adapter #0: NVIDIA GeForce 9800 GT   (nv4_disp.dll) [driver version: 6.14.11.8618]
18:55:25 : Rendering path available: SM2X
18:55:25 : Rendering path available: SM3X
18:55:25 : [gl] CDS init: OK
18:55:25 : [gl] SetPixelFormat: OK (55, color 32 bits, depth 24 bits).
18:55:25 : [gl] wglCreateContext: OK
18:55:25 : [gl] OpenGL framebuffer context init OK
18:55:25 : [gfx] Created drawable (/procedural/truck0.tobj)
18:55:25 : [gfx] Created drawable (/procedural/truck1.tobj)
18:55:25 : [gfx] Created drawable (/procedural/truck2.tobj)
18:55:25 : [gfx] Created drawable (/procedural/truck3.tobj)
18:55:25 : [gfx] Created drawable (/procedural/truck4.tobj)
18:55:25 : [gfx] Created drawable (/procedural/truck5.tobj)
18:55:25 : [gfx] Created drawable (/procedural/truck6.tobj)
18:55:25 : [gfx] Created drawable (/procedural/truck7.tobj)
18:55:25 : [gfx] Created drawable (/procedural/truck8.tobj)
18:55:25 : [gfx] Created drawable (/procedural/truck9.tobj)
18:55:25 : [gfx] Created drawable (/procedural/dashboard.tobj)
18:55:25 : [gfx] Created drawable (/procedural/left_mirror.tobj)
18:55:25 : [gfx] Created drawable (/procedural/right_mirror.tobj)
18:55:25 : [gfx] Created drawable (/procedural/vehicle_env.tobj)
18:55:25 : [gfx] Created drawable (/procedural/generic_env.tobj)
18:55:25 : [gfx] Created drawable (/procedural/water_env.tobj)
18:55:25 : [gfx] Created drawable (/procedural/ocean_env.tobj)
18:55:25 : Setting UI reference mode to: 1152x864...
18:55:25 : [snd] select device (ds8)
18:55:25 : [ds8] Available device : Первичный звуковой драйвер ().
18:55:25 : [ds8] Available device : Realtek HD Audio output (RtkHDAud.sys).
18:55:25 : [ds8] Available device : Realtek HD Audio 2nd output (RtkHDAud.sys).
18:55:25 : [ds8] Initialization OK.
18:55:25 : g_ui_recache
18:55:25 : exit
18:55:27 : [Ode] Starting physics server: Open Dynamics Engine (svn revision 1119)
18:55:27 : Loading city data ....
18:55:27 : Loading cargo descriptions ....
18:55:33 : game
18:55:34 : [Ode] Starting physics server: Open Dynamics Engine (svn revision 1119)
18:55:34 : Loading resource server data ....
18:55:34 : Loading road data ....
18:55:34 : Loading terrain data ....
18:55:34 : Loading railing data ....
18:55:34 : Loading building data ....
18:55:34 : Loading model data ....
18:55:34 : [fs] Unable to open file for reading. (/model/wuppertal/ort/or1.pmd)
18:55:34 : [ld] failed to open /model/wuppertal/ort/or1.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg21.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg21.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg22.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg22.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg23.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg23.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg24.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg24.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg25.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg25.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg27.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg27.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg28.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg28.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg29.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg29.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg30.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg30.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg31.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg31.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg32.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg32.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg33.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg33.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg34.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg34.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg35.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg35.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg36.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg36.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg37.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg37.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg38.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg38.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg39.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg39.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg40.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg40.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg41.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg41.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg42.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg42.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg43.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg43.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg44.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg44.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/misc/eumod/autoa.pmd)
18:55:34 : [ld] failed to open /model/misc/eumod/autoa.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg45.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg45.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg46.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg46.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg47.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg47.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg48.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg48.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg49.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg49.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg50.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg50.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg51.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg51.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg52.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg52.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaz/bruecke60.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaz/bruecke60.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaz/bruecke61.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaz/bruecke61.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaz/bruecke62.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaz/bruecke62.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaz/bruecke63.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaz/bruecke63.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaz/bruecke64.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaz/bruecke64.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaz/bruecke65.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaz/bruecke65.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaz/bruecke66.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaz/bruecke66.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaz/bruecke67.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaz/bruecke67.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaz/bruecke68.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaz/bruecke68.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaz/bruecke80.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaz/bruecke80.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg53.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg53.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg54.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg54.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg55.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg55.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg56.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg56.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg57.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg57.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg58.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg58.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg59.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg59.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg60.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg60.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg61.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg61.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg62.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg62.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg63.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg63.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg64.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg64.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg65.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg65.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg66.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg66.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg67.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg67.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg68.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg68.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg69.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg69.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg70.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg70.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg71.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg71.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg72.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg72.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaz/bruecke69.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaz/bruecke69.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg73.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg73.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg74.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg74.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg75.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg75.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg76.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg76.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg90.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg90.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg91.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg91.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg92.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg92.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg93.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg93.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaz/bruecke81.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaz/bruecke81.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg94.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg94.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg95.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg95.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg96.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg96.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg97.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg97.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign1/blomberg26.pmd)
18:55:34 : [ld] failed to open /sign1/blomberg26.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg21.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg21.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg22.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg22.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg23.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg23.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg24.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg24.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg25.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg25.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg26.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg26.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg27.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg27.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg28.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg28.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg29.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg29.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg30.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg30.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg31.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg31.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg32.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg32.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg33.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg33.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg34.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg34.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg35.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg35.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg36.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg36.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg37.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg37.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg38.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg38.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg39.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg39.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg40.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg40.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg41.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg41.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg42.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg42.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg53.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg53.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg44.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg44.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg45.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg45.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg46.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg46.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg47.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg47.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg48.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg48.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg49.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg49.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg50.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg50.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg51.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg51.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg52.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg52.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg54.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg54.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg55.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg55.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg56.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg56.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg57.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg57.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg58.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg58.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg59.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg59.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign0/blomberg60.pmd)
18:55:34 : [ld] failed to open /sign0/blomberg60.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamas/bruecke00.pmd)
18:55:34 : [ld] failed to open /model/sign/kamas/bruecke00.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamas/bruecke01.pmd)
18:55:34 : [ld] failed to open /model/sign/kamas/bruecke01.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamas/bruecke02.pmd)
18:55:34 : [ld] failed to open /model/sign/kamas/bruecke02.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamas/bruecke03.pmd)
18:55:34 : [ld] failed to open /model/sign/kamas/bruecke03.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamas/bruecke20.pmd)
18:55:34 : [ld] failed to open /model/sign/kamas/bruecke20.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamas/bruecke21.pmd)
18:55:34 : [ld] failed to open /model/sign/kamas/bruecke21.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamas/bruecke22.pmd)
18:55:34 : [ld] failed to open /model/sign/kamas/bruecke22.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamas/bruecke23.pmd)
18:55:34 : [ld] failed to open /model/sign/kamas/bruecke23.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamas/bruecke24.pmd)
18:55:34 : [ld] failed to open /model/sign/kamas/bruecke24.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamas/bruecke25.pmd)
18:55:34 : [ld] failed to open /model/sign/kamas/bruecke25.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamas/bruecke26.pmd)
18:55:34 : [ld] failed to open /model/sign/kamas/bruecke26.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamas/bruecke27.pmd)
18:55:34 : [ld] failed to open /model/sign/kamas/bruecke27.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamas/bruecke28.pmd)
18:55:34 : [ld] failed to open /model/sign/kamas/bruecke28.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamas/bruecke29.pmd)
18:55:34 : [ld] failed to open /model/sign/kamas/bruecke29.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamas/bruecke81.pmd)
18:55:34 : [ld] failed to open /model/sign/kamas/bruecke81.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaa/bruecke00.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaa/bruecke00.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaa/bruecke20.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaa/bruecke20.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaa/bruecke21.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaa/bruecke21.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaa/bruecke22.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaa/bruecke22.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaa/bruecke23.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaa/bruecke23.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaa/bruecke24.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaa/bruecke24.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaa/bruecke25.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaa/bruecke25.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaa/bruecke26.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaa/bruecke26.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaa/bruecke27.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaa/bruecke27.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaa/bruecke28.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaa/bruecke28.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamab/bruecke20.pmd)
18:55:34 : [ld] failed to open /model/sign/kamab/bruecke20.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamab/bruecke21.pmd)
18:55:34 : [ld] failed to open /model/sign/kamab/bruecke21.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamab/bruecke22.pmd)
18:55:34 : [ld] failed to open /model/sign/kamab/bruecke22.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamab/bruecke23.pmd)
18:55:34 : [ld] failed to open /model/sign/kamab/bruecke23.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamab/bruecke24.pmd)
18:55:34 : [ld] failed to open /model/sign/kamab/bruecke24.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamab/bruecke25.pmd)
18:55:34 : [ld] failed to open /model/sign/kamab/bruecke25.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamab/bruecke26.pmd)
18:55:34 : [ld] failed to open /model/sign/kamab/bruecke26.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamab/bruecke27.pmd)
18:55:34 : [ld] failed to open /model/sign/kamab/bruecke27.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamab/bruecke28.pmd)
18:55:34 : [ld] failed to open /model/sign/kamab/bruecke28.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamab/bruecke29.pmd)
18:55:34 : [ld] failed to open /model/sign/kamab/bruecke29.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamab/bruecke60.pmd)
18:55:34 : [ld] failed to open /model/sign/kamab/bruecke60.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamab/bruecke61.pmd)
18:55:34 : [ld] failed to open /model/sign/kamab/bruecke61.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg21.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg21.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg22.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg22.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg23.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg23.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg24.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg24.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg25.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg25.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg26.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg26.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg27.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg27.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg28.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg28.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg29.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg29.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg30.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg30.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg31.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg31.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg32.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg32.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg33.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg33.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg34.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg34.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg35.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg35.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg36.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg36.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg37.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg37.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg38.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg38.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg39.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg39.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign3/blomberg40.pmd)
18:55:34 : [ld] failed to open /sign3/blomberg40.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg21.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg21.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg22.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg22.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg23.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg23.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg24.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg24.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg25.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg25.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg26.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg26.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg27.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg27.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg28.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg28.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg29.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg29.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg30.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg30.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg31.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg31.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg32.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg32.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg33.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg33.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg34.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg34.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg35.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg35.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg36.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg36.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg37.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg37.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg38.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg38.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg39.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg39.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg40.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg40.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg41.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg41.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg42.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg42.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg43.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg43.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg44.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg44.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg45.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg45.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg46.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg46.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg47.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg47.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg48.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg48.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg49.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg49.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg50.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg50.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg51.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg51.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg52.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg52.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg53.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg53.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg54.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg54.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg55.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg55.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg56.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg56.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg57.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg57.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg58.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg58.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg59.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg59.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign4/blomberg60.pmd)
18:55:34 : [ld] failed to open /sign4/blomberg60.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign5/blomberg21.pmd)
18:55:34 : [ld] failed to open /sign5/blomberg21.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign5/blomberg22.pmd)
18:55:34 : [ld] failed to open /sign5/blomberg22.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign5/blomberg23.pmd)
18:55:34 : [ld] failed to open /sign5/blomberg23.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign5/blomberg24.pmd)
18:55:34 : [ld] failed to open /sign5/blomberg24.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamab/bruecke63.pmd)
18:55:34 : [ld] failed to open /model/sign/kamab/bruecke63.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaa/bruecke64.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaa/bruecke64.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamaa/bruecke65.pmd)
18:55:34 : [ld] failed to open /model/sign/kamaa/bruecke65.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign6/blomberg21.pmd)
18:55:34 : [ld] failed to open /sign6/blomberg21.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign6/blomberg22.pmd)
18:55:34 : [ld] failed to open /sign6/blomberg22.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign6/blomberg23.pmd)
18:55:34 : [ld] failed to open /sign6/blomberg23.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign6/blomberg24.pmd)
18:55:34 : [ld] failed to open /sign6/blomberg24.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg26.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg26.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg27.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg27.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg28.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg28.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg29.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg29.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg30.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg30.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg31.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg31.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg32.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg32.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg33.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg33.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg34.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg34.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg35.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg35.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg36.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg36.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg37.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg37.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg38.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg38.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg39.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg39.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg40.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg40.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg41.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg41.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg42.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg42.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg43.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg43.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign7/blomberg44.pmd)
18:55:34 : [ld] failed to open /sign7/blomberg44.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg21.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg21.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg22.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg22.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg23.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg23.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg24.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg24.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamab/bruecke64.pmd)
18:55:34 : [ld] failed to open /model/sign/kamab/bruecke64.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamab/bruecke65.pmd)
18:55:34 : [ld] failed to open /model/sign/kamab/bruecke65.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg37.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg37.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg38.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg38.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg39.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg39.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg40.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg40.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg41.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg41.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg42.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg42.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg43.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg43.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg44.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg44.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign9/blomberg21.pmd)
18:55:34 : [ld] failed to open /sign9/blomberg21.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign9/blomberg22.pmd)
18:55:34 : [ld] failed to open /sign9/blomberg22.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign9/blomberg23.pmd)
18:55:34 : [ld] failed to open /sign9/blomberg23.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign9/blomberg24.pmd)
18:55:34 : [ld] failed to open /sign9/blomberg24.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg25.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg25.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg26.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg26.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg27.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg27.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg28.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg28.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg29.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg29.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg30.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg30.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg31.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg31.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg32.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg32.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg33.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg33.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg34.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg34.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg35.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg35.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign8/blomberg36.pmd)
18:55:34 : [ld] failed to open /sign8/blomberg36.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign9/blomberg25.pmd)
18:55:34 : [ld] failed to open /sign9/blomberg25.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign9/blomberg26.pmd)
18:55:34 : [ld] failed to open /sign9/blomberg26.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign9/blomberg27.pmd)
18:55:34 : [ld] failed to open /sign9/blomberg27.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign9/blomberg29.pmd)
18:55:34 : [ld] failed to open /sign9/blomberg29.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign9/blomberg30.pmd)
18:55:34 : [ld] failed to open /sign9/blomberg30.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign9/blomberg31.pmd)
18:55:34 : [ld] failed to open /sign9/blomberg31.pmd
18:55:34 : [fs] Unable to open file for reading. (/sign9/blomberg32.pmd)
18:55:34 : [ld] failed to open /sign9/blomberg32.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamar/bruecke20.pmd)
18:55:34 : [ld] failed to open /model/sign/kamar/bruecke20.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamar/bruecke21.pmd)
18:55:34 : [ld] failed to open /model/sign/kamar/bruecke21.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/kamar/bruecke22.pmd)
18:55:34 : [ld] failed to open /model/sign/kamar/bruecke22.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke00.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke00.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke01.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke01.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke02.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke02.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke03.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke03.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke04.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke04.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke05.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke05.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke06.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke06.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke07.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke07.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke08.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke08.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke09.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke09.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke20.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke20.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke21.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke21.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke22.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke22.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke23.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke23.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke24.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke24.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke25.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke25.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke26.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke26.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke27.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke27.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke28.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke28.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/bruecke29.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/bruecke29.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/brueckea0.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/brueckea0.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/brueckea1.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/brueckea1.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/brueckea2.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/brueckea2.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/brueckea3.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/brueckea3.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/brueckea4.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/brueckea4.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/brueckea5.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/brueckea5.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/brueckea6.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/brueckea6.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/aamaz/brueckea7.pmd)
18:55:34 : [ld] failed to open /model/sign/aamaz/brueckea7.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/bamaz/bruecke20.pmd)
18:55:34 : [ld] failed to open /model/sign/bamaz/bruecke20.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/bamaz/bruecke21.pmd)
18:55:34 : [ld] failed to open /model/sign/bamaz/bruecke21.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/bamaz/bruecke22.pmd)
18:55:34 : [ld] failed to open /model/sign/bamaz/bruecke22.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/bamaz/bruecke23.pmd)
18:55:34 : [ld] failed to open /model/sign/bamaz/bruecke23.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/bamaz/bruecke24.pmd)
18:55:34 : [ld] failed to open /model/sign/bamaz/bruecke24.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/bamaz/bruecke25.pmd)
18:55:34 : [ld] failed to open /model/sign/bamaz/bruecke25.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/bamaz/bruecke26.pmd)
18:55:34 : [ld] failed to open /model/sign/bamaz/bruecke26.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/bamaz/bruecke27.pmd)
18:55:34 : [ld] failed to open /model/sign/bamaz/bruecke27.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/bamaz/bruecke28.pmd)
18:55:34 : [ld] failed to open /model/sign/bamaz/bruecke28.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/camaz/bruecke20.pmd)
18:55:34 : [ld] failed to open /model/sign/camaz/bruecke20.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/camaz/bruecke21.pmd)
18:55:34 : [ld] failed to open /model/sign/camaz/bruecke21.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/camaz/bruecke22.pmd)
18:55:34 : [ld] failed to open /model/sign/camaz/bruecke22.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/camaz/bruecke23.pmd)
18:55:34 : [ld] failed to open /model/sign/camaz/bruecke23.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/camaz/bruecke24.pmd)
18:55:34 : [ld] failed to open /model/sign/camaz/bruecke24.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/camaz/bruecke25.pmd)
18:55:34 : [ld] failed to open /model/sign/camaz/bruecke25.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/camaz/bruecke26.pmd)
18:55:34 : [ld] failed to open /model/sign/camaz/bruecke26.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/camaz/bruecke27.pmd)
18:55:34 : [ld] failed to open /model/sign/camaz/bruecke27.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/camaz/bruecke28.pmd)
18:55:34 : [ld] failed to open /model/sign/camaz/bruecke28.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/damaz/bruecke00.pmd)
18:55:34 : [ld] failed to open /model/sign/damaz/bruecke00.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/damaz/bruecke01.pmd)
18:55:34 : [ld] failed to open /model/sign/damaz/bruecke01.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/damaz/bruecke20.pmd)
18:55:34 : [ld] failed to open /model/sign/damaz/bruecke20.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/damaz/bruecke21.pmd)
18:55:34 : [ld] failed to open /model/sign/damaz/bruecke21.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/damaz/bruecke22.pmd)
18:55:34 : [ld] failed to open /model/sign/damaz/bruecke22.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/eamaz/bruecke20.pmd)
18:55:34 : [ld] failed to open /model/sign/eamaz/bruecke20.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/eamaz/bruecke21.pmd)
18:55:34 : [ld] failed to open /model/sign/eamaz/bruecke21.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/eamaz/bruecke22.pmd)
18:55:34 : [ld] failed to open /model/sign/eamaz/bruecke22.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/eamaz/bruecke23.pmd)
18:55:34 : [ld] failed to open /model/sign/eamaz/bruecke23.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/eamaz/bruecke24.pmd)
18:55:34 : [ld] failed to open /model/sign/eamaz/bruecke24.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/eamaz/bruecke25.pmd)
18:55:34 : [ld] failed to open /model/sign/eamaz/bruecke25.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/eamaz/bruecke26.pmd)
18:55:34 : [ld] failed to open /model/sign/eamaz/bruecke26.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/eamaz/bruecke27.pmd)
18:55:34 : [ld] failed to open /model/sign/eamaz/bruecke27.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg05.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg05.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg06.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg06.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg07.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg07.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg08.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg08.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg09.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg09.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg10.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg10.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg11.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg11.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg12.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg12.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg13.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg13.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg14.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg14.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg15.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg15.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg16.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg16.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg17.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg17.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg18.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg18.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg19.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg19.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg20.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg20.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg21.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg21.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg22.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg22.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg23.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg23.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg24.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg24.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg25.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg25.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg26.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg26.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg27.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg27.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg28.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg28.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg29.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg29.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg30.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg30.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg31.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg31.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg32.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg32.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg33.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg33.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg34.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg34.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg35.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg35.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg36.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg36.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg37.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg37.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg38.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg38.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg39.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg39.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg40.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg40.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg41.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg41.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg42.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg42.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg43.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg43.pmd
18:55:34 : [fs] Unable to open file for reading. (/aign1/blomberg44.pmd)
18:55:34 : [ld] failed to open /aign1/blomberg44.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg05.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg05.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg06.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg06.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg07.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg07.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg08.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg08.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg09.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg09.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg10.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg10.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg11.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg11.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg12.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg12.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg13.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg13.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg14.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg14.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg15.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg15.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg16.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg16.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg17.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg17.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg18.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg18.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg19.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg19.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg20.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg20.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg21.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg21.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg22.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg22.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg23.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg23.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg24.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg24.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg25.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg25.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg26.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg26.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg27.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg27.pmd
18:55:34 : [fs] Unable to open file for reading. (/bign1/blomberg28.pmd)
18:55:34 : [ld] failed to open /bign1/blomberg28.pmd
18:55:34 : Loading prefab data ....
18:55:34 : Loading sign data ....
18:55:34 : [fs] Unable to open file for reading. (/model/signs/barke.pmd)
18:55:34 : [ld] failed to open /model/signs/barke.pmd
18:55:34 : [fs] Unable to open file for reading. (/model/sign/traffic/lint_enter.pmc)
18:55:34 : [ld] failed to open /model/sign/traffic/lint_enter.pmc
18:55:34 : [fs] Unable to open file for reading. (/model/sign/traffic/border_at.pmc)
18:55:34 : [ld] failed to open /model/sign/traffic/border_at.pmc
18:55:34 : Loading traffic lights data ....
18:55:34 : Loading vegetation data ....
18:55:35 : Loading hinges data ....
18:55:35 : Loading stamp data ....
18:55:35 : Loading movers data ....
18:55:35 : Loading animated models ....
18:55:35 : Loading sound item data ....
18:55:35 : Loading cargo data ....
18:55:35 : Loading company data ....
18:55:35 : Loading city data ....
18:55:35 : Loading cargo descriptions ....
18:55:35 : Map '/map/germany.mbd' loading started ....
18:55:35 : Map successfully loaded ....
18:55:35 : Company item with missing counter part in the economy! (company_name: ) (city_name: aarhus)
18:55:35 : Company item with missing counter part in the economy! (company_name: ) (city_name: breslau)
18:55:35 : Company item with missing counter part in the economy! (company_name: ) (city_name: stettin)
18:55:35 : Company item with missing counter part in the economy! (company_name: ) (city_name: bologna)
18:55:35 : Company item with missing counter part in the economy! (company_name: ) (city_name: kopenhagen)
18:55:35 : Starting the campaign ...
Поставил RKE Map версии 1.11
TsT проблема в экономике, точно не помню, что эта ошибка означает, но или компании криво прописаны, или грузы. Еще могут моды конфликтовать, в частности стоит обратить внимание на эти: RUSGTS.scs, XMapzeug.scs и zzzzzzzGTS Getriebe Reiskorn Map_Bremse beta 0.4.scs.
И как это исправить?И самое главное где это править?
Подскажите пожалуйста как сделать такой свет http://s56.radikal.ru/i153/1109/d8/190c98d800abt.jpg
Отредактировано 2СЕРГЕЙ (2011-09-17 23:47:16)
Скажите пожалуйста в чём проблема? ( Смотрите на бак, солнечнозащитный и номера )
http://www2.picturepush.com/photo/a/6568030/220/All-Screen/gts-00000.jpg
А вот когда приблизишь камеру то всё меняеться
http://www4.picturepush.com/photo/a/6568032/220/All-Screen/gts-00001.jpg
:dontknow:
текстуры пересохрани в фотошопе на dxt 5 и всё  :cool:
Elodar Текстуры пережми!
2СЕРГЕЙ Это мод!
Игра Тормазит Иногда Когда У Поездов Проезжаешь
TsT открываешь свои моды вин раром и в первую очередь проверяешь, чтобы не было одинаковых файлов. Если будут, оставляешь в том моде, ктр для тебя приоритетнее, из остальных удаляешь. Если дубляжа файлов нет, то проверяй прописку фирм и грузов в модах (файлы открывать любым текстовым редактором). Сейчас под рукой игры нет, какие именно файлы сказать не смогу, но это папки "def" и "script". Если не знаешь как прописывать или как должно быть прописано, то или ищи и читай хелпы, или подключай логику и разбирайся сам, впринципе там ничего сложного.
driveable_vehicle_data: vehicle.volvo.fh16.c
brand: "@@trk_volvo_brand@@"
price: 6500
tank_size:900
avg_consumption:33
# models
model: "/vehicle/truck/volvo/truck.pmd"
     lod: "/vehicle/truck/volvo_fh16/lod.pmd"
collision: "/vehicle/truck/volvo/truck.pmc"
     variant: c
fwheel_model: "/vehicle/wheel/fhven/alcoaf1/wheel.pmd"
rwheel_model: "/vehicle/wheel/fhven/alcoar1/wheel.pmd"
# physics params
wheel_mass: 50.0
# Child units
chasis_data: chasis.fh700
sdata_ext: sound.volvo.ext
sdata_int: sound.volvo.int
preview: "volvo"
         game_points: 4
         vehicle_class: 1
interior_camera: camera.interior.volvo.fh16
cabin_cam_off: (0.0, 4.6, -0.6)
top_camera: camera.top.basic
tv_camera: camera.tv.basic
interior_data: interior.volvo.fh16.standard
sleeper: true
#      Red Green Blue Alpha
default_colors[]:( 23,  36,  73, 255)
# used for UI truck rendering
reflection_offset: (0.0, 4.8, 0.0)
# upgrade prices
upgrade_power1:5000
upgrade_power2:7000
upgrade_handling1:7000
upgrade_handling2:9000
upgrade_consumption1:1000
upgrade_consumption2:1500
upgrade_consumption3:3100
facts[]: "353 kW (480 @@ui_hp@@) 2400 Nm, V6 12.8l"
facts[]: "9-@@ui_speeds@@"
facts[]: "600 l"
парни посмотрите мод, прописал по хелпу под версию 1.00 (РТС) , но чего-то не идет( нет в игре) может я чего-то не то сделал?
chasis_data: chasis.fh700 не может быть такого
Приветствую!!!
Я новенький на этом форуме, объясните пожалуйста такая проблема скачал GTS запустил всё нормально игра работает....Ставлю допустим какой нибудь грузовик половина текстур не отображается, игра работает в режиме Директс, а когда переключаешь на Open GL всё нормально всё отображается, но игра жутко тормозит!!!!!
Помогите пожалуйста если возможно как нибудь это исправить!!!!
Кирилл(WETT)
но я этой строчки не косался...
ребят помоги плс. нужно камеру чуть отдалить от лобовухи и приблизить к задней стенке. как это сделать?
Вылетает Дополнение В Посте 53 Карты В Чем Проблема Даже Зайти Не Получаеться
чё за ё***** рот б**??!!! Решил переписать фред сенчури с новой мордой из етс в гтс. Всё сделал по хелпу ДЖО. В конце загрузки выдаёт ошибку! Что за фигня? :mad: Кроме хелпов джо пользовался левыми какими то. Пробовал газексус переписать для гтс пассажирский так он пошёл! в чём проблема то? помогите пожалуста. Все жмотят своими х**приватными "золотыми" фредами. Вот пытаюсь сам...
Отредактировано kamaz102rus (2011-09-21 15:33:14)
хелп скачал Russian map for ATS(austrian truck simulator) и вот такая проблема http://i062.radikal.ru/1109/51/bd05f0a8605ft.jpg  http://s13.radikal.ru/i186/1109/62/0601bd388242t.jpg
Semir
карта коректно работает на версии 1.0.0 ,
о чем везде и всюду было написано,
и не факт ,что пофиксили до 1.3.2.
играй на первой версии остальное все было в описании
и кажеццо
вот что написано  в ридми есле ты его читал
Russian map for GTS beta 1.0 by stalker45&Санёк
Мод корректно работает только на GTS версии 1.0
Никто не исключает возможность вылетов и лагов
Версия мода не финальная.
и прочее
Может мне все-таки кто-нибудь ответит на мой вопрос? ^
да да и на мой!!!  :flag:
kamaz102rus Гаец
Киньте мне ссылки, попробую сделать...
kamaz102rus
И напиши версию твоей игры.
Отредактировано _Niko_ (2011-09-24 22:03:17)
Подскжите пожалуйста в чём проблема http://i022.radikal.ru/1109/2b/f3d8d5410b8bt.jpg,заранее благодарен
2СЕРГЕЙ
Пережми текстуры в фотошопе в DXT5
Добрые люди,
у меня такой вопрос: кто-нибудь пытался запустить игру в системе linux с помощью программы wine? Если да, и игра пошла, то как быть с драйвером руля G25? Нужно ли его поместить в автозапуск или запускать вручную каждый раз?
И ещё вопросик: у меня пока не получилось установить патчи. Как исхитриться поставить?
:tomato:
Отредактировано untermensch (2011-09-26 13:38:30)
У меня назревает не вопрос, а скорее просьба - кто сможет приписать к фреду салон из д3 на версию 1.0? _Niko_, за что ему отдельное спасибо, всё же переписал для меня (пока что, для меня) Freightliner. Ему, всмысле фреду, единственное чего не хватает - именно салона. Кому не сложно - жду ответа :hobo:
p.s. - знаю что надо давно уже было научиться и т.п., но мой ПК наотрез не хочет запускать Zанозу...(
Отредактировано kamaz102rus (2011-10-04 09:37:48)
У меня проблема следующая на карте РТС версия 1.0 не доезжая до  Гороховца вылетает игра еду со стороны Москвы...
OSTeam, стандартная ситуация когда вылетаешь у новгорода. у гороховца у меня всё как на мази) самое интересное если с новгорода едешь в сторону москвы - всё норм. Скорее всего у тебя какой то мод конфликтует
и кое что от меня: Слив приватов продолжается :D вот скачал фред колумбия - у него салон как раз для центрика. зацените -
http://i026.radikal.ru/1110/f2/eb9b29638cd6t.jpg
http://s001.radikal.ru/i196/1110/2d/57cf64fa1388t.jpg
http://s16.radikal.ru/i191/1110/36/abd8e86405a0t.jpg
Жаль что для версии выше 1.0   Может есть  кто и прописать сможет и зеркала рабочими сделать? В приваты не уйдёт. Сейчас попробую с шпунтом договориться на изменение салона у модели + выкладывание :crazy:
Отредактировано kamaz102rus (2011-10-06 12:41:26)
kamaz102rus
Да нет проблема в том что Вылет идет и все... А сенсей нечего не пишет..
Что эти строчки в логе значат и как исправить вылет при входе в редактор?  :question:
20:41:52 : [fs] Unable to open file for reading. (/material/editor/germany.dds)
20:41:52 : [dds] Can not load '/material/editor/germany.dds'
20:41:52 : mm_flush
20:41:52 : Map '/map/germany.mbd' loading started ....
20:41:52 : Map successfully loaded ....
20:42:01 : f:\devel\eurotruck_at\prism\src\p3core\collections/arrays/arrays_base_impl.h(466): ??A?$array_t@V?$owner_ptr_t@Vmodel_def_u@prism@@@prism@@@prism@@QAEAAV?$owner_ptr_t@Vmodel_def_u@prism@@@1@I@Z: Index outside array boundaries.
