Problem with map editing
Сообщений 1 страница 2 из 2
Hi all. I have a little problem. Then I want to insert road I push "E" button in English keyboard. Then I have this problem:
http://www.part.lt/img/5c4c1e5263bb026a4fb9f72b99ffe041806.JPG
I can't push that table "Road item default properties". What can I do to fix that problem?
Greetings from Lithuania.
Thanks for help.
Отредактировано Arranger (2010-11-14 19:36:02)
hi friend...
this is a russian speaking forum, so try expressing yourself in appropriate language so that everyone could understand you thanks...
as for you prolem i dont quite get it. you cant make the item properties window active, can you? if so - use alt+tab combination to switch between active windows lol ;)
