Сообщений 271 страница 300 из 575
From       Sterling (CO) Global Beers
To            Salmon (ID) Wallbert
Cargo      Cold Smoke   1069 mile x 0,50$ =534,5$ (7381,5$)
http://images.vfl.ru/ii/1621598651/c05bc3ef/34535328_s.jpg http://images.vfl.ru/ii/1621598651/378f8a54/34535329_s.jpg http://images.vfl.ru/ii/1621598651/d8e32aed/34535330_s.jpg
From      Salmon (ID) Wallbert
To            Spokane (WA) Rail Export
Cargo      Mississppi Mud    701 mile x 0,50$ =350,5$ (7732$)
http://images.vfl.ru/ii/1621598707/276ef6a7/34535359_s.jpg http://images.vfl.ru/ii/1621598707/1cdbdbef/34535360_s.jpg http://images.vfl.ru/ii/1621598708/c23672cc/34535361_s.jpg
From      Los Angeles (CA) Beer Trucking Co.
To            Salt Lake City  (UT) Sell Goods
Cargo      Corona Extra    689 mile x 0,50$ =344,5$ (8076,5$)
http://images.vfl.ru/ii/1624786990/01711d3f/34962245_s.jpg http://images.vfl.ru/ii/1624786991/743b4d7f/34962246_s.jpg http://images.vfl.ru/ii/1624786992/c170264c/34962248_s.jpg
AlexSar
Вечер добрый.
Обновился я до версии 1.41 и при запуске профиля выдает такую ошибку:
00:00:26.916 : <ERROR> [unit] File '<C:/Users/Sergey/Documents/American Truck Simulator/mod/ATS BeerMod Colorado v.1.39.scs | >/def/world/railing.dlc.co.sii', line 9:
00:00:26.916 : <ERROR> [unit] The unit name 'railing.co_4' is already taken by an existing unit (of type 'railing_model').
00:00:26.916 : <ERROR> load_filtered_unit_array() - Failed to load units from file (/def/world/railing.dlc.co.sii)
00:00:26.916 : <ERROR> Data error. (/def/world/railing.sii)
00:00:26.917 : Loading building data ....
00:00:26.938 : Loading model data ....
00:00:26.971 : <ERROR> [unit] File '<C:/Users/Sergey/Documents/American Truck Simulator/mod/ATS BeerMod Colorado v.1.39.scs | >/def/world/model.dlc_co.sii', line 120:
00:00:26.971 : <ERROR> [unit] The unit name 'model.co_0r006' is already taken by an existing unit (of type 'model_def').
00:00:26.971 : <ERROR> load_filtered_unit_array() - Failed to load units from file (/def/world/model.dlc_co.sii)
00:00:26.979 : <ERROR> Data error. (/def/world/model.sii)
00:00:26.984 : <ERROR> [unit] File '<C:/Users/Sergey/Documents/American Truck Simulator/mod/ATS BeerMod Colorado v.1.39.scs | >/def/world/far_model.dlc_co.sii', line 16:
00:00:26.984 : <ERROR> [unit] The unit name 'far_model.co_15002' is already taken by an existing unit (of type 'far_model_def').
00:00:26.984 : <ERROR> load_filtered_unit_array() - Failed to load units from file (/def/world/far_model.dlc_co.sii)
00:00:26.985 : Loading animated models ....
00:00:27.000 : Loading prefab data ....
00:00:27.033 : <ERROR> [unit] File '<C:/Users/Sergey/Documents/American Truck Simulator/mod/ATS BeerMod Colorado v.1.39.scs | >/def/world/prefab.dlc_co.sii', line 47:
00:00:27.033 : <ERROR> [unit] The unit name 'prefab.d_food_plnt4' is already taken by an existing unit (of type 'prefab_model').
00:00:27.033 : <ERROR> load_filtered_unit_array() - Failed to load units from file (/def/world/prefab.dlc_co.sii)
00:00:27.035 : <ERROR> Data error. (/def/world/prefab.sii)
00:00:27.170 : Loading sign data ....
00:00:27.185 : <ERROR> [unit] File '<C:/Users/Sergey/Documents/American Truck Simulator/mod/ATS BeerMod Colorado v.1.39.scs | >/def/world/sign.dlc_co.sii', line 23:
00:00:27.185 : <ERROR> [unit] The unit name 'sign.co_03002' is already taken by an existing unit (of type 'sign_model').
00:00:27.186 : <ERROR> load_filtered_unit_array() - Failed to load units from file (/def/world/sign.dlc_co.sii)
00:00:27.186 : <ERROR> Data error. (/def/world/sign.sii)
Lukas49
Попробуй отключить в ММ мод BTC Colorado. У тебя останется только основной пивной мод.
После выхода Колорадо я не смог его интегрировать в основной мод, поэтому получилось два мода. Возможно, что-то пошло не так после выхода 1.41. Пока не занимался пивным модом, жду Вайоминг.
From      Ontario (OR) Wallbert
To            Olympia  (WA)  Wailbert
Cargo      Founders    461 mile x 0,50$ =230,5$ (8307$)
http://images.vfl.ru/ii/1628314510/3b3413cf/35415374_s.jpg http://images.vfl.ru/ii/1628314511/95dcf283/35415375_s.jpg http://images.vfl.ru/ii/1628314511/ebb70a4d/35415376_s.jpg
From      Yakima (WA) Global Beer
To           Pocatello (ID)  Chemso
Cargo     Procces Water   550 mile x 0,50$ =275$ (8582$)
http://images.vfl.ru/ii/1631902213/e553e898/35903151_s.jpg http://images.vfl.ru/ii/1631902213/f25e8fb9/35903152_s.jpg http://images.vfl.ru/ii/1631902213/af2c0bf2/35903153_s.jpg
From      Рино (NV) Wallbert
To           Джекпот (SW)  Sell Goods
Cargo     Halia  367 mile x 0,50$ =183.5$
http://upforme.ru/uploads/0000/2a/c0/23500/t889916.jpg http://upforme.ru/uploads/0000/2a/c0/23500/t443105.jpg http://upforme.ru/uploads/0000/2a/c0/23500/t612416.jpg
From      Elko (NV) Rail Export
To           Ontario (OR)  Global Beers
Cargo     Brewing Water   265 mile x 0,50$ =132,5$ (8714,5$)
http://images.vfl.ru/ii/1632498505/db1a6b5a/35998259_s.jpg http://images.vfl.ru/ii/1632498505/f30db718/35998260_s.jpg http://images.vfl.ru/ii/1632498506/d0d7ab92/35998261_s.jpg
From      Ontario (OR)  Global Beers
To           Sandpoint (ID)  Deepgrouve
Cargo     Old Pallets   419 mile x 0,50$ =209,5$ (8924$)
http://images.vfl.ru/ii/1632498574/64e17a20/35998276_s.jpg http://images.vfl.ru/ii/1632498575/cc2b2452/35998277_s.jpg http://images.vfl.ru/ii/1632498575/e5e4f614/35998278_s.jpg
Произошли изменения в конфигурации пивного мода, теперь он состоит из одного файла. Пиво присутствует в Колорадо и Вайоминге.
From      Гранд-Джаксан (Co) Wallbert
To          Стимбот-Спрингс (Co)  Wallbert
Cargo    Fatso  250 mile x 0,50$ =125.0$
http://upforme.ru/uploads/0000/2a/c0/23500/t170259.jpg http://upforme.ru/uploads/0000/2a/c0/23500/t964196.jpg http://upforme.ru/uploads/0000/2a/c0/23500/t538439.jpg
From      Стимбот-Спрингс (Co)  Wallbert
To          Форт-Коллинс (Co)  Wallbert
Cargo     Fatso  199 mile x 0,50$ =99.5$
http://upforme.ru/uploads/0000/2a/c0/23500/t441337.jpg http://upforme.ru/uploads/0000/2a/c0/23500/t213072.jpg http://upforme.ru/uploads/0000/2a/c0/23500/t862289.jpg
Отредактировано Ден Федорович (2021-09-28 09:17:18)
From      Couer d`Alene (ID)  Wallbert
To           Twin Falls (ID)  Sell Goods
Cargo     Founders Porter  412 mile x 0,50$ =206$ (9130$)
http://images.vfl.ru/ii/1633447605/47e1a6e0/36136166_s.jpg http://images.vfl.ru/ii/1633447606/9a1821bd/36136167_s.jpg http://images.vfl.ru/ii/1633447606/f3b80641/36136168_s.jpg
From      Coos Bay (OR)  Wallbert
To           Tacoma (WA)  Port of Tacoma
Cargo     Halia 369 mile x 0,50$ =184,5$ (9314,5$)
http://images.vfl.ru/ii/1633447657/6ee553ca/36136174_s.jpg http://images.vfl.ru/ii/1633447658/c0acc477/36136175_s.jpg http://images.vfl.ru/ii/1633447658/76ceb9a7/36136176_s.jpg
From      Alamosa (CO)  Wallbert
To           Jackson (WY)  Wallbert
Cargo     Tenn No. 12     728 mile x 0,50$ =364$ (9678,5$)
http://images.vfl.ru/ii/1633888610/e892157a/36198588_s.jpg http://images.vfl.ru/ii/1633888611/fc6987aa/36198589_s.jpg http://images.vfl.ru/ii/1633888611/5284cb51/36198590_s.jpg
From      Albuquerque (NM)  Global Beers
To           Cheyenne (WY)  Chemso
Cargo     Process Water     549 mile x 0,50$ =274,5$ (9953$)
http://images.vfl.ru/ii/1634312843/d30fc68b/36273849_s.jpg http://images.vfl.ru/ii/1634312843/1f898684/36273850_s.jpg http://images.vfl.ru/ii/1634312843/7c40f5b6/36273851_s.jpg
From      Twin Falls (ID) Wallbert
To           Bend (OR)  Wallbert
Cargo     Mississippi   Mud    406 mile x 0,50$ =203$ (10156$)
http://images.vfl.ru/ii/1634312949/b68ad070/36273873_s.jpg http://images.vfl.ru/ii/1634312949/448924d2/36273874_s.jpg http://images.vfl.ru/ii/1634312949/794d7514/36273875_s.jpg
From      Medford (OR) Bushnell
To           Ontario (OR)  Global Berrs
Cargo    Brewing Water  418 mile x 0,50$ =209$ (10365$)
http://images.vfl.ru/ii/1634750262/7c949caa/36344472_s.jpg http://images.vfl.ru/ii/1634750262/4ccc4256/36344473_s.jpg http://images.vfl.ru/ii/1634750262/923f76c1/36344474_s.jpg
From      Ontario (OR)  Global Berrs
To           Ketchum (ID)  Sell Goods
Cargo    Fargo Original   178 mile x 0,50$ = 89$ (10454$)
http://images.vfl.ru/ii/1634750341/7e0084ab/36344496_s.jpg http://images.vfl.ru/ii/1634750341/f1e7a061/36344497_s.jpg http://images.vfl.ru/ii/1634750341/3b4b4ca7/36344498_s.jpg
To           Fort Collins (CO)  Sell Goods
Cargo    Halia   678 mile x 0,50$ = 339$ (10793$)
http://images.vfl.ru/ii/1634750435/990c34e2/36344528_s.jpg http://images.vfl.ru/ii/1634750435/b72ccc67/36344529_s.jpg http://images.vfl.ru/ii/1634750435/3d6e22b1/36344531_s.jpg
From      Fort Collins (CO)  Wallbert
To           Santa Fe (NM)  Wallbert
Cargo    Mississippi Mud   420 mile x 0,50$ = 210$ (11003$)
http://images.vfl.ru/ii/1635012486/083a4684/36386647_s.jpg http://images.vfl.ru/ii/1635012487/5037dab2/36386648_s.jpg http://images.vfl.ru/ii/1635012487/92e085f7/36386649_s.jpg
From       Santa Fe (NM)  Wallbert
To           Durango (CO)  Tidbit
Cargo    Helm`s Deep   188 mile x 0,50$ =94$ (11097$)
http://images.vfl.ru/ii/1635012556/ca62816d/36386658_s.jpg http://images.vfl.ru/ii/1635012556/860dc657/36386659_s.jpg
From      Durango (CO)  Wallbert
To           Ogden (UT)  Sell Goods
Cargo    Black Diamond  398 mile x 0,50$ = 199$ (11296$)
http://images.vfl.ru/ii/1635617668/ddc6a29d/36480534_s.jpg http://images.vfl.ru/ii/1635617668/86fb7f8b/36480535_s.jpg http://images.vfl.ru/ii/1635617669/da714aaf/36480536_s.jpg
From      Ogden (UT)  Wallbert
To           Kennewick (WA)  Rail Export
Cargo    Tenn No. 12     573 mile x 0,50$ = 286,5$ (11582,5$)
http://images.vfl.ru/ii/1635617756/cf7fb0a1/36480582_s.jpg http://images.vfl.ru/ii/1635617756/80f61e60/36480583_s.jpg http://images.vfl.ru/ii/1635617756/06c422e1/36480584_s.jpg
From      Стимбот - Спрингс (CO)  Walmart
To          Примм (NV)  Walmar
Cargo    Candi  665 mile x 0,50$ = 332.5 $
http://upforme.ru/uploads/0000/2a/c0/23500/t529262.jpg http://upforme.ru/uploads/0000/2a/c0/23500/t375843.jpg http://upforme.ru/uploads/0000/2a/c0/23500/t622317.jpg
From      Pendleton (OR)  Wallbert
To           Colville (WA)  Sell Goods
Cargo    Good Gourd    219 mile x 0,50$ = 109,5$ (11 692$)
http://images.vfl.ru/ii/1636126557/4899c3f0/36560943_s.jpg http://images.vfl.ru/ii/1636126557/7808a18b/36560944_s.jpg http://images.vfl.ru/ii/1636126558/64929ad6/36560945_s.jpg
From      Sandpoint (ID)  Wallbert
To           Grangeville (ID)  Wallbert
Cargo    Tyranena      232 mile x 0,50$ = 116$ (11808$)
http://images.vfl.ru/ii/1636126628/97c8907b/36560961_s.jpg http://images.vfl.ru/ii/1636126628/b23a5f25/36560962_s.jpg http://images.vfl.ru/ii/1636126628/5a82fdde/36560963_s.jpg
From      Grangeville (ID)  Wallbert
To           Gillette (WY)  Rail Export
Cargo     Candi    966 mile x 0,50$ = 483$ (12291$)
http://images.vfl.ru/ii/1636565042/c6261dda/36636050_s.jpg http://images.vfl.ru/ii/1636565042/072d9143/36636051_s.jpg http://images.vfl.ru/ii/1636565042/ed7ba6ba/36636052_s.jpg
From      Rock Springs (WY)  Wallbert
To           Colorado Springs (CO)  Sell Goods
Cargo     Schmidt`s    475mile x 0,50$ = 237,5$ (12528,5$)
http://images.vfl.ru/ii/1636565113/39ef1231/36636063_s.jpg http://images.vfl.ru/ii/1636565113/3d031d36/36636064_s.jpg http://images.vfl.ru/ii/1636565113/c16559b7/36636065_s.jpg
From      Riverton (WY)  Crops
Cargo     Brewing Water    633 mile x 0,50$ = 316,5$ (12845$)
http://images.vfl.ru/ii/1636565186/c291e9f8/36636076_s.jpg http://images.vfl.ru/ii/1636565186/6ec44a55/36636077_s.jpg http://images.vfl.ru/ii/1636565186/41b95276/36636078_s.jpg
From      Ontario (OR)   Crops
To           Yakima (WA) Global Beers
Cargo     Brewing Water    323 mile x 0,50$ = 161,5$ (13006,5$)
http://images.vfl.ru/ii/1637168668/3f5f5dfc/36729544_s.jpg http://images.vfl.ru/ii/1637168668/0dc2e2d9/36729545_s.jpg http://images.vfl.ru/ii/1637168668/8e7ee637/36729546_s.jpg
From      Yakima (WA) Global Beers
To           Bakersfield (CA) Chemso
Cargo     Process Water    988 mile x 0,50$ = 494$ (13500,5$)
http://images.vfl.ru/ii/1637168748/0d289c4f/36729563_s.jpg http://images.vfl.ru/ii/1637168748/7975fbf8/36729564_s.jpg http://images.vfl.ru/ii/1637168749/af955e11/36729565_s.jpg
From      Примм (NV) Walmart
To          Камп Верде (Az) Walmart
Cargo     Sinkhole Stout    305 mile x 0,50$ = 152,5$
http://upforme.ru/uploads/0000/2a/c0/23500/t943839.jpghttp://upforme.ru/uploads/0000/2a/c0/23500/t960588.jpghttp://upforme.ru/uploads/0000/2a/c0/23500/t643674.jpg
From      Камп Верде (Az) Walmart
To          Аламоса (Co) Walmart
Cargo     Halia 596 mile x 0,50$ = 298,0$
http://upforme.ru/uploads/0000/2a/c0/23500/t990921.jpghttp://upforme.ru/uploads/0000/2a/c0/23500/t593209.jpghttp://upforme.ru/uploads/0000/2a/c0/23500/t469105.jpg
From      Gallup (NM) Wallbert
Cargo     Backwoods Bastard    763 mile x 0,50$ = 381,5$ (13882$)
http://images.vfl.ru/ii/1637502749/82e9868c/36776758_s.jpg http://images.vfl.ru/ii/1637502750/5a17494d/36776759_s.jpg http://images.vfl.ru/ii/1637502750/4b9b14c8/36776760_s.jpg
To           Ukiah (CA) Wallbert
Cargo     Tenn No. 12    709 mile x 0,50$ = 354,5$ (14236,5$)
http://images.vfl.ru/ii/1637502804/ee54f787/36776766_s.jpg http://images.vfl.ru/ii/1637502804/931aadd4/36776767_s.jpg http://images.vfl.ru/ii/1637502804/0f0d7eae/36776768_s.jpg
From       Аламоса (Co) Walmart
To           Нампа (ID) Walmart
Cargo     Tyranena  880 mile x 0,50$ = 440,0$
http://upforme.ru/uploads/0000/2a/c0/23500/t465488.jpg http://upforme.ru/uploads/0000/2a/c0/23500/t95303.jpg  http://upforme.ru/uploads/0000/2a/c0/23500/t218144.jpg
From       Ukiah (CA) Wallbert
To            Newport (OR) Tidbit
Cargo     Good Gourd    526 mile x 0,50$ = 263$ (14499,5$)
http://images.vfl.ru/ii/1638010937/831f9767/36857941_s.jpg http://images.vfl.ru/ii/1638010937/c55c5a91/36857942_s.jpg http://images.vfl.ru/ii/1638010937/315f6746/36857943_s.jpg
Cargo     Brewing Water   419 mile x 0,50$ = 209,5$ (14709$)
http://images.vfl.ru/ii/1638010998/43c934ca/36857968_s.jpg http://images.vfl.ru/ii/1638010998/36e15749/36857969_s.jpg http://images.vfl.ru/ii/1638010999/2bfa229c/36857970_s.jpg
To            Eugene (OR) Beer Trucking Co.
Cargo     Wort    402 mile x 0,50$ = 201$ (14910$)
http://images.vfl.ru/ii/1638011062/55e01e5a/36857981_s.jpg http://images.vfl.ru/ii/1638011062/46616e90/36857982_s.jpg http://images.vfl.ru/ii/1638011063/83253a3a/36857983_s.jpg
А куда из мода делись def/cargo/beer01...05.sii?..  o.O
Старую версию мода под старую версию игры давно потёр, ничего не осталось.  :blush:
Knox_xss, Сам в шоке!!  :huh:  Через два часа доберусь до основного кома и займусь. На флешке есть версии мода под игру 1.36, если чё переброшу.
ВНИМАНИЕ!! Мод перезалит!
Добавлены недостающие файлы папки def ( def/cargo/beer01...05.sii)
Теперь снова стали доступны грузы для хоппера (пшеница, хмель, рожь...).
P.S. Саша, спасибо за невольную подсказку решения проблемы с грузами для хоппера. Наверное, когда возился с объединением двух архивов мода в один, этот момент упустил и ... забыл :'(  Позже всю голову изломал куда делись пшеница, хмель ?  :tired:
А они разве не были доступны?..  :unsure:  Вроде как beer01..05 - для рефов и фургонов.
По поводу пшеницы (btcblrs.sii) - она указана только на ввоз (в Global Beers), на вывоз её нет нигде. С остальными хопперовскими вроде всё норм (есть и на ввоз, и на вывоз).
Но в самой игре не смотрел, есть грузы для хоппера или нет.  :confused:
А то завис я что-то намертво в ATS. :hobo: Дай, думаю, хоть пиво повожу... пока муза АТС-ная от меня не улетела. :)
В том то и дело, что нет. Если помнишь одно время мод содержал два архива: основной и Colorado (ну не шло пиво другим способом из Colorado). В версии игры 1.41 попробовал сделать объединение. Мод стал поддерживать Colorado, но позже заметил, что невозможно работать с хоппером - нет грузов. Возможно, я что-то менял  :huh: не помню, долго с модом не работал.
Мы ты как-то с Максом в мультиплеере катались и разговор зашёл как бы BeerMod  в онлайне обкатать  ;)
Саша, я их, наверное, "переписал" как-то...
From       Colville (WA) Crops
To            Cedar City (UT) Global Beers
Cargo      Brewing Water    971 mile x 0,50$ = 485,5$ (15395,5$)
http://images.vfl.ru/ii/1638201743/92b6f29c/36882975_s.jpg http://images.vfl.ru/ii/1638201743/221c6a3d/36882976_s.jpg http://images.vfl.ru/ii/1638201743/bc1df05d/36882977_s.jpg
From       Tucumcari (NM) Crops
To            Sterling (CO) Global Beers
Cargo      Wheat    577 mile x 0,50$ = 288,5$ (15684$)
http://images.vfl.ru/ii/1638201850/098bcf71/36883011_s.jpg http://images.vfl.ru/ii/1638201851/04d4880d/36883012_s.jpg http://images.vfl.ru/ii/1638201851/78154a23/36883013_s.jpg
