Вы здесь » PlayTruck.2bb.ru - Дальнобойщики, Euro Truck Simulator, American Truck Simulator » American Truck Simulator » American Truck Simulator [Обсуждение]
Сообщений 811 страница 840 из 996
811
Supric Вот real_g27_ffb.log
Log opened
read from ini, FFB/steering_force = 90.000000
read from ini, FFB/damper_force = 0.000000
read from ini, FFB/steering_speed = 100.000000
read from ini, FFB/tyre_self_stabilization = 66.000000
read from ini, FFB/steering_stift_base = 800.000000
read from ini, FFB/steering_stift_speed = 200.000000
read from ini, FFB/steering_workzone = 4000
read from ini, FFB/steering_stift_param = 20
read from ini, FFB/vibration_force_engine = 0.000000
read from ini, FFB/vibration_force_overload = 0.000000
read from ini, LEDS/leds_mode = 3
read from ini, LEDS/leds_mode_switch_button_number = 3
read from ini, LEDS/leds_real_time_scale = 1
read from ini, LEDS/rest_total = 12
read from ini, LEDS/brake_temp_max = 199
read from ini, LEDS/rpm_min = 1000
read from ini, LEDS/rpm_max = 2400
read from ini, LEDS/fuel_warning = 250
read from ini, LEDS/fuel_min = 50
read from ini, LEDS/del_time_max = 12
read from ini, LEDS/fuel_cons_min = 20
read from ini, LEDS/fuel_cons_max = 50
read from ini, LEDS/cargo_wear_min = 1
read from ini, LEDS/cargo_wear_max = 6
read from ini, WHEEL_ANGLES/castor_angle = 2.500000
read from ini, WHEEL_ANGLES/camber_angle = 1.000000
read from ini, WHEEL_ANGLES/kingpin_angle = 7.750000
read from ini, WHEEL_ANGLES/half_axle_length = 0.120000
read from ini, WHEEL_ANGLES/steer_range = 20
Logitech Profiler
American Truck Simulator [Ьащ
Plugins
UIRibbonDockTop
Ribbon
Ribbon
Plugins
Plugins
Plugins
Movies & TV
Movies & TV
Calculator
Calculator
Microsoft Solitaire Collection
19:01
Program Manager
FolderView
Configuration: substances
  id[0] : string = static
  id[1] : string = road
  id[2] : string = road_snow
  id[3] : string = dirt
  id[4] : string = snow
  id[5] : string = grass
  id[6] : string = road_dirt
  id[7] : string = invis
  id[8] : string = ice
  id[9] : string = metal
  id[10] : string = rubber
  id[11] : string = rumble_stripe
  id[12] : string = plastic
  id[13] : string = wood
  id[14] : string = glass
  id[15] : string = soft
Configuration: job
delivery time = 0
Configuration: controls
Configuration: hshifter
Configuration: truck
Retrieving truck params...
Configuration: trailer
Configuration: job
delivery time = 1504
  cargo.id : string = emptytank
  cargo : string = Цистерна
  cargo.mass : float = 10205.900391
  destination.city.id : string = tonopah
  destination.city : string = Tonopah
  source.city.id : string = fresno
  source.city : string = Fresno
  destination.company.id : string = sc_frm
  destination.company : string = Sunshine Crops
  source.company.id : string = pns_con_sit
  source.company : string = Plaster & Sons
  income : u64 = 3066
  delivery.time : u32 = 1504
  shifter.type : string = hshifter
  selector.count : u32 = 2
  selector.count[0] : u32 = 2
  slot.gear[0] : s32 = 0
  slot.handle.position[0] : u32 = 0
  slot.selectors[0] : u32 = 0
  slot.gear[1] : s32 = 0
  slot.handle.position[1] : u32 = 0
  slot.selectors[1] : u32 = 1
  slot.gear[2] : s32 = 0
  slot.handle.position[2] : u32 = 0
  slot.selectors[2] : u32 = 2
  slot.gear[3] : s32 = 0
  slot.handle.position[3] : u32 = 0
  slot.selectors[3] : u32 = 3
  slot.gear[4] : s32 = -1
  slot.handle.position[4] : u32 = 1
  slot.selectors[4] : u32 = 0
  slot.gear[5] : s32 = -3
  slot.handle.position[5] : u32 = 1
  slot.selectors[5] : u32 = 1
  slot.gear[6] : s32 = -2
  slot.handle.position[6] : u32 = 1
  slot.selectors[6] : u32 = 2
  slot.gear[7] : s32 = -4
  slot.handle.position[7] : u32 = 1
  slot.selectors[7] : u32 = 3
  slot.gear[8] : s32 = 1
  slot.handle.position[8] : u32 = 2
  slot.selectors[8] : u32 = 0
  slot.gear[9] : s32 = 13
  slot.handle.position[9] : u32 = 2
  slot.selectors[9] : u32 = 1
  slot.gear[10] : s32 = 7
  slot.handle.position[10] : u32 = 2
  slot.selectors[10] : u32 = 2
  slot.gear[11] : s32 = 13
  slot.handle.position[11] : u32 = 2
  slot.selectors[11] : u32 = 3
  slot.gear[12] : s32 = 2
  slot.handle.position[12] : u32 = 3
  slot.selectors[12] : u32 = 0
  slot.gear[13] : s32 = 14
  slot.handle.position[13] : u32 = 3
  slot.selectors[13] : u32 = 1
  slot.gear[14] : s32 = 8
  slot.handle.position[14] : u32 = 3
  slot.selectors[14] : u32 = 2
  slot.gear[15] : s32 = 14
  slot.handle.position[15] : u32 = 3
  slot.selectors[15] : u32 = 3
  slot.gear[16] : s32 = 3
  slot.handle.position[16] : u32 = 4
  slot.selectors[16] : u32 = 0
  slot.gear[17] : s32 = 15
  slot.handle.position[17] : u32 = 4
  slot.selectors[17] : u32 = 1
  slot.gear[18] : s32 = 9
  slot.handle.position[18] : u32 = 4
  slot.selectors[18] : u32 = 2
  slot.gear[19] : s32 = 15
  slot.handle.position[19] : u32 = 4
  slot.selectors[19] : u32 = 3
  slot.gear[20] : s32 = 4
  slot.handle.position[20] : u32 = 5
  slot.selectors[20] : u32 = 0
  slot.gear[21] : s32 = 16
  slot.handle.position[21] : u32 = 5
  slot.selectors[21] : u32 = 1
  slot.gear[22] : s32 = 10
  slot.handle.position[22] : u32 = 5
  slot.selectors[22] : u32 = 2
  slot.gear[23] : s32 = 16
  slot.handle.position[23] : u32 = 5
  slot.selectors[23] : u32 = 3
  slot.gear[24] : s32 = 5
  slot.handle.position[24] : u32 = 6
  slot.selectors[24] : u32 = 0
  slot.gear[25] : s32 = 17
  slot.handle.position[25] : u32 = 6
  slot.selectors[25] : u32 = 1
  slot.gear[26] : s32 = 11
  slot.handle.position[26] : u32 = 6
  slot.selectors[26] : u32 = 2
  slot.gear[27] : s32 = 17
  slot.handle.position[27] : u32 = 6
  slot.selectors[27] : u32 = 3
  slot.gear[28] : s32 = 6
  slot.handle.position[28] : u32 = 7
  slot.selectors[28] : u32 = 0
  slot.gear[29] : s32 = 18
  slot.handle.position[29] : u32 = 7
  slot.selectors[29] : u32 = 1
  slot.gear[30] : s32 = 12
  slot.handle.position[30] : u32 = 7
  slot.selectors[30] : u32 = 2
  slot.gear[31] : s32 = 18
  slot.handle.position[31] : u32 = 7
  slot.selectors[31] : u32 = 3
truck.wheels.count = 6
truck.wheel.base = 6.396956
  brand_id : string = kenworth
  brand : string = Kenworth
  id : string = vehicle.kenworth.t680
  name : string = T680
  fuel.capacity : float = 833.000000
  adblue.capacity : float = 80.000000
  rpm.limit : float = 2500.000000
  gears.forward : u32 = 18
  gears.reverse : u32 = 4
  differential.ratio : float = 3.080000
  retarder.steps : u32 = 0
  forward.ratio[0] : float = 12.190000
  forward.ratio[1] : float = 10.400000
  forward.ratio[2] : float = 8.510000
  forward.ratio[3] : float = 7.260000
  forward.ratio[4] : float = 6.050000
  forward.ratio[5] : float = 5.160000
  forward.ratio[6] : float = 4.380000
  forward.ratio[7] : float = 3.740000
  forward.ratio[8] : float = 3.200000
  forward.ratio[9] : float = 2.730000
  forward.ratio[10] : float = 2.280000
  forward.ratio[11] : float = 1.940000
  forward.ratio[12] : float = 1.620000
  forward.ratio[13] : float = 1.380000
  forward.ratio[14] : float = 1.170000
  forward.ratio[15] : float = 1.000000
  forward.ratio[16] : float = 0.860000
  forward.ratio[17] : float = 0.730000
  reverse.ratio[0] : float = -13.090000
  reverse.ratio[1] : float = -11.170000
  reverse.ratio[2] : float = -3.500000
  reverse.ratio[3] : float = -2.990000
  cabin.position : fvector = (0.000000,3.000000,-2.000000)
  head.position : fvector = (-0.505394,-0.530493,0.793030)
  hook.position : fvector = (0.000000,1.000000,2.704638)
  fuel.warning.factor : float = 0.150000
  adblue.warning.factor : float = 0.150000
  brake.air.pressure.warning : float = 65.000000
  brake.air.pressure.emergency : float = 30.000000
  oil.pressure.warning : float = 10.000000
  water.temperature.warning : float = 105.000000
  battery.voltage.warning : float = 22.000000
  wheels.count : u32 = 6
  wheel.position[0] : fvector = (-1.099985,0.536000,-2.956251)
  wheel.steerable[0] : bool = true
  wheel.simulated[0] : bool = true
  wheel.radius[0] : float = 0.516373
  wheel.powered[0] : bool = false
  wheel.position[1] : fvector = (1.099985,0.536000,-2.956251)
  wheel.steerable[1] : bool = true
  wheel.simulated[1] : bool = true
  wheel.radius[1] : float = 0.516373
  wheel.powered[1] : bool = false
  wheel.position[2] : fvector = (-0.943309,0.536084,3.440706)
  wheel.steerable[2] : bool = false
  wheel.simulated[2] : bool = true
  wheel.radius[2] : float = 0.515767
  wheel.powered[2] : bool = true
  wheel.position[3] : fvector = (0.943309,0.536084,3.440706)
  wheel.steerable[3] : bool = false
  wheel.simulated[3] : bool = true
  wheel.radius[3] : float = 0.515767
  wheel.powered[3] : bool = true
  wheel.position[4] : fvector = (-0.943309,0.536084,2.096224)
  wheel.steerable[4] : bool = false
  wheel.simulated[4] : bool = true
  wheel.radius[4] : float = 0.515767
  wheel.powered[4] : bool = true
  wheel.position[5] : fvector = (0.943309,0.536084,2.096224)
  wheel.steerable[5] : bool = false
  wheel.simulated[5] : bool = true
  wheel.radius[5] : float = 0.515767
  wheel.powered[5] : bool = true
  id : string = flatbed_b.trailer.chassis
  cargo.accessory.id : string = etank.flatbed.cargo
  hook.position : fvector = (0.000000,1.000000,-5.966383)
  wheels.count : u32 = 4
  wheel.position[0] : fvector = (-0.957128,0.557709,5.162177)
  wheel.steerable[0] : bool = false
  wheel.radius[0] : float = 0.520000
  wheel.position[1] : fvector = (0.957128,0.557709,5.162177)
  wheel.steerable[1] : bool = false
  wheel.radius[1] : float = 0.520000
  wheel.position[2] : fvector = (-0.957128,0.557687,3.902690)
  wheel.radius[2] : float = 0.520000
  wheel.powered[2] : bool = false
  wheel.position[3] : fvector = (0.957128,0.557687,3.902690)
  wheel.radius[3] : float = 0.520000
  wheel.powered[3] : bool = false
Telemetry unpaused
init timer
initialized timer = 20364
Telemetry paused
Before clean: g_wheel 0, 0
After clean: kt_res 1, g_wheel 0, 0
Log ended
У всех у кого зависает на создании профиля
У мну зависает как с антивирусом, так и без него, как с предложенными здесь сейвами, так и без них. Ставил другую версию репака с крякалкой для 64-битных систем, -то же самое. Может, это особенность windows 10?
Supric написал(а):
Лог самого плагина глянь. Там отладочная инфа была, в версии 2.3.
пардонте
Log opened
15:48
TF_FloatingLangBar_WndTitle
FolderView
Program Manager
Configuration: job
delivery time = 0
Configuration: job
delivery time = 4497
  cargo.id : string = machine_pts
  cargo : string = Автозапчасти
  cargo.mass : float = 9979.099609
  destination.city.id : string = santa_cruz
  destination.city : string = Santa Cruz
  source.city.id : string = san_diego
  source.city : string = San Diego
  destination.company.id : string = bit_rd_grg
  destination.company : string = Bitumen
  source.company.id : string = vm_car_whs
  source.company : string = Voltison
  income : u64 = 4924
  delivery.time : u32 = 4497
  selector.count : u32 = 1
  selector.count[0] : u32 = 1
  slot.gear[2] : s32 = -1
  slot.handle.position[2] : u32 = 1
  slot.selectors[2] : u32 = 0
  slot.gear[3] : s32 = -2
  slot.handle.position[3] : u32 = 1
  slot.selectors[3] : u32 = 1
  slot.gear[4] : s32 = 1
  slot.handle.position[4] : u32 = 2
  slot.gear[5] : s32 = 2
  slot.handle.position[5] : u32 = 2
  slot.gear[6] : s32 = 3
  slot.handle.position[6] : u32 = 3
  slot.selectors[6] : u32 = 0
  slot.gear[7] : s32 = 4
  slot.handle.position[7] : u32 = 3
  slot.selectors[7] : u32 = 1
  slot.gear[8] : s32 = 5
  slot.handle.position[8] : u32 = 4
  slot.gear[9] : s32 = 6
  slot.handle.position[9] : u32 = 4
  slot.handle.position[10] : u32 = 5
  slot.selectors[10] : u32 = 0
  slot.gear[11] : s32 = 8
  slot.handle.position[11] : u32 = 5
  slot.selectors[11] : u32 = 1
  slot.gear[12] : s32 = 9
  slot.handle.position[12] : u32 = 6
  slot.gear[13] : s32 = 10
  slot.handle.position[13] : u32 = 6
  slot.gear[14] : s32 = 0
  slot.handle.position[14] : u32 = 7
  slot.selectors[14] : u32 = 0
  slot.gear[15] : s32 = 0
  slot.handle.position[15] : u32 = 7
  slot.selectors[15] : u32 = 1
truck.wheel.base = 5.225673
  brand_id : string = peterbilt
  brand : string = Peterbilt
  id : string = vehicle.peterbilt.579
  name : string = 579
  fuel.capacity : float = 568.000000
  gears.forward : u32 = 10
  gears.reverse : u32 = 2
  differential.ratio : float = 2.850000
  forward.ratio[0] : float = 15.420000
  forward.ratio[1] : float = 11.520000
  forward.ratio[2] : float = 8.550000
  forward.ratio[3] : float = 6.280000
  forward.ratio[4] : float = 4.670000
  forward.ratio[5] : float = 3.300000
  forward.ratio[6] : float = 2.460000
  forward.ratio[7] : float = 1.830000
  forward.ratio[8] : float = 1.340000
  forward.ratio[9] : float = 1.000000
  reverse.ratio[0] : float = -18.180000
  reverse.ratio[1] : float = -3.890000
  head.position : fvector = (-0.536855,-0.573093,0.662799)
  hook.position : fvector = (0.000000,1.000000,1.384683)
  wheel.position[0] : fvector = (-1.100000,0.536000,-2.959135)
  wheel.position[1] : fvector = (1.100000,0.536000,-2.959135)
  wheel.position[2] : fvector = (-0.943000,0.536084,2.266538)
  wheel.position[3] : fvector = (0.943000,0.536084,2.266538)
  wheel.position[4] : fvector = (-0.943000,0.536084,1.093643)
  wheel.position[5] : fvector = (0.943000,0.536084,1.093643)
  id : string = gooseneck_r.trailer.chassis
  cargo.accessory.id : string = container_s.gooseneck_r.cargo
  hook.position : fvector = (0.000000,1.000000,-5.560199)
  wheel.position[0] : fvector = (-0.957128,0.538570,5.247515)
  wheel.position[1] : fvector = (0.957128,0.538570,5.247515)
  wheel.position[2] : fvector = (-0.957128,0.538548,3.989499)
  wheel.position[3] : fvector = (0.957128,0.538548,3.989499)
Log ended
windows 10 х64 все нормально...вообще проблем 0...
Мишаня666
Все, понял, там по имени окно игры ищется. Плагин настроен на ETS2. Надо видимо в настройку выносить.
Или попытаться запустить так, чтобы при запуске игры имя окна было "Euro Truck Simulator 2" )))
А ничего что это одна версия игры? По вашему их куча? :rofl:
Да, игра идет только на х64!
Отредактировано Mauser (2016-01-31 18:09:38)
Mauser написал(а):
По вашему их куча?
будет в будущем  :D
да уж, вот это я понимаю проработка городов :) Теперь как-то будет не комильфо, если scs не приведут детализацию ЕТС2 в соответствии с АТС  :crazyfun:
100% потому что команда другая.  ;)
Вы представьте какая получится огромная карта когда все штаты запилят.  o.O  :huh:  :rolleyes:  :)
Отредактировано Mauser (2016-01-31 18:29:26)
обнаружил косячок - при выполнении первой миссии, на заставке с крутящимся гаражом написано что как заработаете денег, сможете свободно передвигаться по Европе  :D
да уж, яб проехал от побережья к побережью  :rolleyes:
По времени мне кажется, из одного конца карты в другой будет столько же, сколько в ETS2.
Масштаб какой то другой здесь, как то здесь заметно быстрее километраж накручивается, поиграл по времени совсем чуть чуть, а накатано уже почти 3к километров (1700 миль)
Ребята.. вот тока тока тащил цистерну дизтоплива... она длинющая до жути... при съезде с шоссе в город нужно было повернуть налево... и короче телега на встречке осталась и почти цепляла пропускающий меня тягач...
Не знаю с какой обновой это вышло (!), но этот тягач сдал задним ходом метра 2, чтобы я смог пролезть!!! Я в шокееее.. я просто по-новому полюбил серию!!!
Только будет раза в 3-4 больше.  Заметь что в ETS2 прямых дорог почти нет.
Две Еуропы + Сканди...
А по сути распаковать, и посмотреть в редакторе масштаб карты, и всё все вопросы - адью...
Отредактировано ШАМАН (2016-01-31 19:05:24)
Вот и меня терзают смутные сомнения
Так то не спорю, и вообще, исходя из того в каком состоянии сейчас карта, я понимаю, что был проделан колоссальный объем работ, мне очень понравилось.
И даже как то обидно за ETS2. Хочется, чтобы они уже взялись и переделали "Старую" Европу хотя бы чуть чуть, ибо она с первой части все та же, однообразная и унылая
Отредактировано Koloss (2016-01-31 19:12:47)
Появится Вольво, хотя не понимаю почему его нема (лицуха ток на Еуропу?). тогда и я глядишь дёрну в пендосию за зеленью =)
Мда, карта реально маленькая. За пару часов открыл уже  10% карты..  :glasses:
Надеюсь, весной выпустят ДЛЦ с Невадой/Орегоном (Невадой/Аризоной?). В целом -- оптимизация вполне, фпс стабилен, за редким исключением (перед развязками)..
з.ы. Консоль не работает -- хотел прописать warp 0.7; каким-то другим образом это возможно сделать (поменять скорость течения времени/скорости движения авто)?
А что за сцепление можете сказать , продвинутая понятно , а в чём разница , упрощённая и упрощённая+сигнал ?
Невада уже есть и вскоре обещали аризону выпустить
может быть имеется в виду сигнализация о необходимости переключиться? В настройках клавиш есть что-то с этим связанное  :dontknow:
Игра кстати гораздо шустрее чем ЕТС работает. Поставил масштаб 300%, на моей гтх760 фпс 40-50. С 200% стабильно 60 (может и больше по факту, но включил вертикальную синхронизацию чтоб дроссели не свистели). В ЕТС катался со 150% кажется, там 60 фпс не выдает
Отредактировано Maddreg (2016-01-31 19:48:11)
ребят, а никто не проверял настройку камеры в кабине?  настройки не сохраняются,каждый раз приходится занова настраивать камеру,я имею ввиду настройку камеры из главного меню игры,  пока в рейсе,все нормально, если брать новый рейс, настройки камеры слетают на дефолт,как это можно исправить?
консоль тоже что ли не работает ?
Хм... ехешник игры самоудалился с компа - чтот енто мне оочень не нравитсо...
Эта хрень, которую обнаружил Каспер и которую я изначально не удалил... ооочень вредная хрень.... удалите  и просканируйте комп...
Отредактировано ШАМАН (2016-01-31 20:08:52)
работает консоль нормально, не хуже чем в ETS2
ребят а скиньте ссылку на распаковщик, что то мой етсвский не берет архивы
даблсцепки не завезли  я полагаю?
Короче парни, выдерайте игру, что по раздаче с ЯДиска и что с ней установилось... там биткоинтмайнинг и куча игр. за которые владельцу раздачи бонусы капают...
Нет конечно. :(
, а на какой файл конкретно ругается?
Отредактировано Koloss (2016-01-31 20:28:31)
А вы думали там чистый дистриб будет? Наивные )))
Из каспера дорожку невозможно скопировать...
c:users\имя юзера\appdata\local\temp\rar(значёк доллара)ex00.214\ats2016\setup.exe
Раздачи от HATAB чистые, проверено... а енто шляпа голимая.
Отредактировано ШАМАН (2016-01-31 20:41:32)
Очень понравилась физика разгона, раньше такое можно было получить увеличением веса прицепа, да и то сейчас тягач как то по другому ощущается, в ETS такого  чувства не было, можно сказать сделали если не совсем реалистично, то уже гораздо ближе. Похоже теперь у них  какой то новый алгоритм. Трафик тоже теперь не  чувствуется игрушечным, разгон стал плавным особенно у фур. Еще заметил у  легковушек начала работать подвеска, при заходе в поворот появляется поперечный крен, неужели им прикрутили физику? Что огорчило, очень надеялся увидеть в списке повреждений тормозную систему, но нет, какой смысл пользоваться ретардером, если тормоза не изнашиваются? Даже в древних дальнобойщиках 3 этот момент реализовали, а эти упрямо игнорируют, жаль. Еще мне показалось, что вес грузов как то немного занижен, у европейцев объем трейлера вроде бы меньше, но берут 18-20 тонн, а здесь как будто на половину груженые.
Ну так в ЕТС это сделали.
Вообще то на междуштатных у них пониже допуск, кажется 36 тонн полная масса, а в Европе 40 минимум.
Ну так и в ЕТС они как бы давно не летают.
