Если кто может помочь разобраться в чем причина вылета при попытке купить авто через онлайн, но когда захожу в салон, то он просто пустой ![]()
Вот лог
00:00:32.752 : <ERROR> [unit] File '/def/vehicle/truck_dealer/mercedes/mercedes_3.sii', line 40:
00:00:32.752 : <ERROR> Included at '/def/vehicle/truck_dealer/mercedes.sii', line 17:
00:00:32.752 : <ERROR> [unit] The values in array attribute 'accessories' of unit '.tdealer.mercedes_3' (of type 'vehicle') must be specified in order - trying to set the element 14 of array of size 13.
00:00:32.752 : <ERROR> load_unit_tree() - Failed to load unit tree from file (/def/vehicle/truck_dealer/mercedes.sii)
00:00:44.095 : <ERROR> [unit] File '/def/vehicle/truck_dealer/mercedes/mercedes_3.sii', line 40:
00:00:44.095 : <ERROR> Included at '/def/vehicle/truck_dealer/mercedes.sii', line 17:
00:00:44.095 : <ERROR> [unit] The values in array attribute 'accessories' of unit '.tdealer.mercedes_3' (of type 'vehicle') must be specified in order - trying to set the element 14 of array of size 13.
00:00:44.096 : <ERROR> load_unit_tree() - Failed to load unit tree from file (/def/vehicle/truck_dealer/mercedes.sii)
00:00:44.097 : <ERROR> [unit] File '/def/vehicle/truck_dealer/mercedes/mercedes_3.sii', line 40:
00:00:44.097 : <ERROR> Included at '/def/vehicle/truck_dealer/mercedes.sii', line 17:
00:00:44.098 : <ERROR> [unit] The values in array attribute 'accessories' of unit '.tdealer.mercedes_3' (of type 'vehicle') must be specified in order - trying to set the element 14 of array of size 13.
00:00:44.098 : <ERROR> load_unit_tree() - Failed to load unit tree from file (/def/vehicle/truck_dealer/mercedes.sii)
Я понимаю что проблема в прописке дилера. Но что именно?
Отредактировано Stas556 (2013-11-10 22:34:11)
