Сообщений 1 страница 30 из 1096
Поделиться22012-06-23 06:16:23
Мужики, при запуске выкидывает из игры и выдает:
SCANIA Truck Driving Simulator - обнаружена ошибка. Приложение будет закрыто. Приносим извинения за неудобства.
game.log
******** : log created on : Monday June 18 2012 @ 00:19:37
00:19:37 : [sys] running on x86 / Windows 98 x86 (version 4.10)
00:19:37 : [sys] DirectX version : 4.09.00.0904
00:19:37 : [cpu] GenuineIntel [ Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz] 4 logical processor(s) at ~3292MHz.
00:19:37 : [sys] Using 2 worker thread(s)
00:19:37 : [sys] using QPC / ACPI (PM Clock) timer, frequency 3579545Hz
00:19:37 : [mem] physical memory detected (2079372K/1400040K)
00:19:37 : [mem] virtual memory detected (2097024K/2048148K)
00:19:37 : [mem] Trying to allocate memory pool (204800K)
00:19:37 : [hashfs] base.scs: Using public key 'final'
00:19:37 : [hashfs] base.scs: Digital signature valid
00:19:37 : [hashfs] base.scs: Mounted ok, 19625 entries
00:19:37 : [hashfs] def.scs: Using public key 'final'
00:19:37 : [hashfs] def.scs: Digital signature valid
00:19:37 : [hashfs] def.scs: Mounted ok, 731 entries
00:19:37 : [hashfs] locale.scs: Using public key 'final'
00:19:37 : [hashfs] locale.scs: Digital signature valid
00:19:37 : [hashfs] locale.scs: Mounted ok, 103 entries
00:19:37 : [hashfs] base_cfg.scs: Using public key 'final'
00:19:37 : [hashfs] base_cfg.scs: Digital signature valid
00:19:37 : [hashfs] base_cfg.scs: Mounted ok, 1 entries
00:19:37 : [ufs] Home directory: 'H:/Documents and Settings/Администратор/Мои документы/SCANIA Truck Driving Simulator'.
00:19:37 : exec /home/config.cfg
00:19:37 : [sys] Executing /home/config.cfg ...
00:19:37 : uset r_full_resolution_corrections "0"
00:19:37 : uset r_force_color_shadowmaps "0"
00:19:37 : uset g_ortho_scale "1"
00:19:37 : uset g_ortho_draw "0"
00:19:37 : uset g_replay_gc "1"
00:19:37 : uset g_news "-1"
00:19:37 : uset r_segment_cache_behavior "3"
00:19:37 : uset r_use_depth_bounds "1"
00:19:37 : uset r_show_light_pixel_coverage "0"
00:19:37 : uset r_mirror_scale_y "1.0"
00:19:37 : uset r_mirror_scale_x "1.0"
00:19:37 : uset r_scale_y "1.0"
00:19:37 : uset r_scale_x "1.0"
00:19:37 : uset r_sunshafts "1"
00:19:37 : uset r_color_saturation "1.0"
00:19:37 : uset r_color_yellow_blue "0.0"
00:19:37 : uset r_color_magenta_green "0.0"
00:19:37 : uset r_color_cyan_red "0.0"
00:19:37 : uset r_color_correction "1"
00:19:37 : uset r_dof_filter_size "0.5"
00:19:37 : uset r_dof_transition "400.0"
00:19:37 : uset r_dof_start "200.0"
00:19:37 : uset r_dof "1"
00:19:37 : uset r_mlaa_threshold "1.0"
00:19:37 : uset r_mlaa "1"
00:19:37 : uset r_hdr "1"
00:19:37 : uset r_fake_shadows "2"
00:19:37 : uset r_sun_shadow_texture_size "4096"
00:19:37 : uset r_sun_shadow_quality "4"
00:19:37 : uset r_deferred_mirrors "1"
00:19:37 : uset r_deferred "1"
00:19:37 : uset r_startup_progress "1"
00:19:37 : uset r_setup_done "0"
00:19:37 : uset r_gamma "1.0"
00:19:37 : uset r_nv_stereo_mode "2"
00:19:37 : uset r_msaa "0"
00:19:37 : uset r_fullscreen "1"
00:19:37 : uset r_mode "1024x768x32x0"
00:19:37 : uset r_path ""
00:19:37 : uset r_device "dx9"
00:19:37 : uset g_pedestrian "1"
00:19:37 : uset g_light_span_factor "1.0"
00:19:37 : uset g_light_distance_factor "1.0"
00:19:37 : uset g_vehicle_flare_lights "1"
00:19:37 : uset g_auto_traffic_headlights "1"
00:19:37 : uset g_auto_traffic "1"
00:19:37 : uset g_kdop_preview "0"
00:19:37 : uset g_screenshot_on_bug "0"
00:19:37 : uset g_developer "0"
00:19:37 : uset g_wc_fps "0.0"
00:19:37 : uset g_wc_radius "-1.0"
00:19:37 : uset g_flyspeed "100.0"
00:19:37 : uset g_colbox "0"
00:19:37 : uset g_radio_mode "1"
00:19:37 : uset g_ignore_low_fps "0"
00:19:37 : uset g_truck_light_quality "1"
00:19:37 : uset g_truck_light_specular "1"
00:19:37 : uset g_gfx_all_scales "0"
00:19:37 : uset g_gfx_advanced "0"
00:19:37 : uset g_gfx_quality "-1"
00:19:37 : uset g_menu_aa_limit "8"
00:19:37 : uset g_additional_water_fov "20.0f"
00:19:37 : uset g_rain_reflect_hookups "1"
00:19:37 : uset g_rain_reflect_actor "1"
00:19:37 : uset g_rain_reflect_traffic "1"
00:19:37 : uset g_rain_reflect_cache "1"
00:19:37 : uset g_rain_reflection "3"
00:19:37 : uset g_reflection "3"
00:19:37 : uset g_detail_veg "2"
00:19:37 : uset g_minicon "0"
00:19:37 : uset g_console "0"
00:19:37 : uset g_texture_usage_stats "0"
00:19:37 : uset g_fps "0"
00:19:37 : uset g_stream_exts ".ogg;.mp3"
00:19:37 : uset r_vsync "1"
00:19:37 : uset r_anisotropy_factor "0.25"
00:19:37 : uset r_texture_detail "0"
00:19:37 : It looks like the game did crash during last startup, triggering safe mode
00:19:37 : [lang] Language autodetection: 419
00:19:37 : Selected language: ru_ru
00:19:37 : SCANIA Truck Driving Simulator init ver.1.0.0 (rev. 39276)
00:19:37 : [net] LOG INFO: Started
00:19:37 : Setting UI reference mode to: 1440x900...
00:19:37 : Render device override: dx9
00:19:37 : [gfx] Selected rendering device: dx9
00:19:37 : [dx9] NVAPI initialized
00:19:37 : [dx9] Direct3D9 detected.
00:19:37 : [dx9] Number of adapters found: 1
00:19:38 : [dx9] Adapter #0: NVIDIA GeForce GT 440 (1024 MB)
00:19:38 : [dx9] Adapter #0: nv4_disp.dll (version: 6.14.12.7533/20110525)
00:19:38 : [dx9] Using SM3X rendering path
00:19:38 : [gfx] Trying to set 1024x768 32bpp 60Hz (fullscreen)
00:19:38 : [dx9] Stereo fully allowed.
00:19:38 : [dx9] Stereo enable query failed: 4294967293
00:19:38 : [dx9] D3D9 device sucessfully created [HWVP]
OS windows xp. 3д инструктор, траинз 2012, дальнобойщики 3 идут без проблем на высокой графике. Те проблема врядли в железе.
Народ на windows xp играет, так что дело не в ОС. Подскажите что делать!
Поделиться32012-06-23 10:07:53
привет
Я использую Google переводчик
У меня есть проблема с моего мода на колеса для водителя Scania, колесо не имеет тени
http://freddmasterr.picturepush.com/sho … clid=58416
Может кто поможет мне?
Спасибо.
Поделиться42012-06-23 19:19:31
freddmasterr, Эти строки в файле def\vehicle\truck\scania.r\chassis есть?
extended_shadow_texture: "/vehicle/truck/scania_rcab_2009/shadow_4x2.tobj"
extended_shadow_intensity: 1.05
extended_shadow_fadeout_start: 10
extended_shadow_fadeout_length: 0
Поделиться52012-06-23 20:25:24
ШАМАН, да, это то же самое.
Я не редактировал грузовик, просто колеса.
Я скачал колеса Scania (Джо), я заметил, структуры на колеса, а также два мата, front.fakeshadow.mat, front.shadowonly.mat
Я не использовал их. Была ли эта проблема?
Еще одна вещь, у кого-то есть Mat_extractor?
Mat_extractor загрузка не работает.
(Http :/ / wwwmultiupload.com/EV7S05B5F5)
Спасибо.
Поделиться62012-06-23 21:06:01
Ребят а в игру можно конвертнуть Stralis чтобы у него кабина качалась?
Поделиться72012-06-23 21:44:55
А вольву VNL670 никто не пробовал ещё перенести в STDS?
очень бы хотелось увидеть)
Поделиться82012-06-23 22:11:41
В этом и есть проблема. Делать надо по образцу
Поделиться92012-06-23 22:13:12
В игру можно конвертить все,лишь-бы голова на плечах была.
Поделиться102012-06-23 23:06:25
У меня не открывает файл base.scs пишет архив повреждён или имеет неизвестный формат,а файлы .scs из ГТС открывает .Что делать?
Поделиться112012-06-23 23:07:12
Мужики кто знает...у меня габариты горят...а отражений от габаритов нет...в чём проблема?Ссылка
Отредактировано Andress (2012-06-23 23:07:32)
Поделиться122012-06-24 03:25:28
графон повыше поставь
Поделиться132012-06-24 06:08:04
На сайте игры есть конвертор для распаковки базы. Вот здесь.
Отредактировано Mauser (2012-06-24 06:13:54)
Поделиться142012-06-24 08:52:34
Когда я установил патч 1.1.0,у меня выкидывает,пишет мол того программа не отвечает. ОС WIndiws7 x64 Home premium лицензия
Поделиться152012-06-24 13:10:57
Спасибо!
Поделиться162012-06-24 13:41:19
Подскажите как сделать чтоб кабина больше покачивалась ?
Поделиться172012-06-24 21:02:03
Кто нибудь пробовал заставить работать нормально геймпад (у меня аналог хбоксовского)?Управление рулем работает на левом стике(как и положено),а вот газ и тормоз не возмножно поставить на нижнее тигеры(на верхние можно,но с ними невозможно регулировать подачу газу и степень нажатия на тормоза).
Поделиться182012-06-25 10:33:29
Привет всем. У меня в плейере mp3 файлы не проигрываются. Может кто знает в чем проблема, может их в меньший битрейт перекодировать, или он по-старинке только ogg-и понимает?
Поделиться192012-06-25 12:27:47
а в какой папке находятся характеристики машины
Поделиться202012-06-25 17:28:52
парни подскажите я вскрыл эту игру но заноза не открывает что делать подскажите
Поделиться212012-06-25 19:53:24
Попробуй удалить PMC файл из папки с машиной.
Поделиться222012-06-25 20:20:11
Алекс 01 нет ошибка
Поделиться232012-06-27 15:43:50
Добрый день.
Подскажите пожалуйста,как поменять отображение на дисплее авто индикацию номера передачи.
Тоесть:1; 2; 3; и тд. на 1; 1Н; 2; 2Н и тд.
Поделиться242012-06-27 18:39:44
У мнея геймпад от иксбокса и все замечательно работает
Поделиться252012-06-28 00:43:53
привет всем скачал игру с оф сайта пытался распоковать базу не получается пишит архив повреждён или имеет неизвестный формат. Скачал утилиту для распаковки scs файлов серавно пишет тоже самое. Может я че не правильно делаю он даже открытую базу так пишет. Я скачал открытую базу и бестолку пытался заменить на открытую базу. Игра не запускается.
к стати я пытаюсь запустить утилиту распоковки файлов scs мелькает черный экран и не чего не происходит. Пытался запустить правой кнопкой мыши выбрать распоковать серавно игра не распаковывается пишет архив повреждён или имеет неизвестный формат. Перекидовал на другой диск серавно тоже самое
Отредактировано Aleksei26 (Сегодня 00:51:50)
Отредактировано Aleksei26 (2012-06-28 00:55:47)
Поделиться262012-06-28 09:12:50
"Новое поколение"...
Это консольная программа. Запускай либо из консоли scs_extractor.exe <scs file name>, либо перетягивай архив на иконку с распаковщиком.
Поделиться272012-06-28 13:18:57
Или другой метод. Правой кнопкой мыши на SCS, открыть с помощью scs_extractor.exe. И ждать пока всё распакуется.
Поделиться282012-06-28 14:07:50
Может и не по теме но все же
Поставил эту карту. А где это место на карте ?
Поделиться292012-06-28 23:31:09
как только заежаешь на новый участок дороги,поворот направо,и по пути встретишь
Поделиться302012-06-29 02:39:57
Может кому пригодится. Сам долго искал, но в интернете решения не было...
Проблема - не работает поворот головы (камеры) ни с кнопок / * ни Alt+мышкой и смена видов ( по numpad) в кабине.
Решение - идем в Документы\SCANIA Truck Driving Simulator\profile\ваш_пофайл\controls.sii. Ищем строку config_lines[108]: "mix trackiron `trackir.device.active?0`" и меняем на config_lines[108]: "mix trackiron `trackir.device.unactive?0`" (изменение выделенно жирным). Сохраняем, запускаем игру и "крутим головой"
P.S. тракира никогда не было, игра официальная демка. Почему активировался тракир неизвестно.
Отредактировано DragonNZ (2012-06-29 02:41:03)
