Сообщений 991 страница 1000 из 1000
991
Ребят как это исправить???http://s003.radikal.ru/i202/1106/da/5cfa4e22dc3ft.jpg Вот лог
******** : log created on : Monday June 20 2011 @ 18:42:57
18:42:57 : [sys] running on x86 / Windows XP (version 5.1) / Service Pack 3
18:42:57 : [sys] DirectX version : 4.09.00.0904
18:42:57 : [cpu] AuthenticAMD [AMD Turion™ 64 X2 Mobile Technology TL-52] at ~1607MHz.
18:42:57 : [cpu] Features utilized: fpu cmov mmx mmxext 3dnow 3dnowext sse sse2.
18:42:57 : [sys] using QPC / ACPI (PM Clock) timer (thread affinity: 0), frequency 3579545Hz
18:42:57 : physical memory detected (1047140K/369292K)
18:42:57 : virtual memory detected (2097024K/2061032K)
18:42:57 : Trying to allocate memory pool (409600K)
18:42:57 : [zipfs] base.scs: mounted ok, 9452 entries [crc_0xb9a6ed95]
18:42:57 : [ufs] registered symlink from /custom_build/en_gb to /
18:42:57 : [zipfs] <mem-addr-file>: mounted ok, 11 entries [crc_0x32159817]
18:42:57 : [ufs] Home directory: 'C:/Documents and Settings/user/My Documents/Euro Truck Simulator'.
18:42:57 : Mounting extra package: C:/Documents and Settings/user/My Documents/Euro Truck Simulator/mod/volvo.scs
18:42:57 : [zipfs] C:/Documents and Settings/user/My Documents/Euro Truck Simulator/mod/volvo.scs: mounted ok, 35 entries [crc_0x1c799690]
18:42:57 : exec /home/config.cfg
18:42:57 : [sys] Executing /home/config.cfg ...
18:42:57 : uset g_minicon "0"
18:42:57 : uset g_console "1"
18:42:57 : uset g_trackir "1"
18:42:57 : uset g_developer "1"
18:42:57 : uset g_save_idx "1"
18:42:57 : uset g_mouse_control "0"
18:42:57 : uset g_steering_func_param "0.0"
18:42:57 : uset g_joy_axis_brake_dz "0.0"
18:42:57 : uset g_joy_axis_brake "7"
18:42:57 : uset g_joy_ff_gain "1.0"
18:42:57 : uset g_joy_axis_throttle_dz "0.0"
18:42:57 : uset g_joy_axis_throttle "7"
18:42:57 : uset g_joy_axis_ff "0"
18:42:57 : uset g_joy_axis_combine "0"
18:42:57 : uset g_joy_axis_steer_sens "0.6"
18:42:57 : uset g_joy_axis_steer_dz "0.0"
18:42:57 : uset g_joy_axis_steer "7"
18:42:57 : uset g_tutorial "1"
18:42:57 : uset g_job_sort "0"
18:42:57 : uset g_gauges "1"
18:42:57 : uset g_mirrors "1"
18:42:57 : uset g_fatigue "1"
18:42:57 : uset g_police "1"
18:42:57 : uset g_subtitles "0"
18:42:57 : uset g_quality "0"
18:42:57 : uset g_reflection "0"
18:42:57 : uset g_atrans "1"
18:42:57 : uset g_flyspeed "100.0"
18:42:57 : uset g_lang "en_gb"
18:42:57 : uset g_colbox "0"
18:42:57 : uset r_gamma "1.0"
18:42:57 : uset r_path "5"
18:42:57 : uset r_msaa "4"
18:42:57 : uset r_fullscreen "0"
18:42:57 : uset r_mode "800x600x32x0"
18:42:57 : uset r_device "gl"
18:42:57 : uset r_driver "gl"
18:42:57 : uset g_texture_usage_stats "0"
18:42:57 : uset g_fps "0"
18:42:57 : uset ds8_mix_channels "2"
18:42:57 : uset ds8_mix_depth "16"
18:42:57 : uset ds8_mix_rate "44100"
18:42:57 : uset ds8_reverse_stereo "0"
18:42:57 : uset s_acceleration "0"
18:42:57 : uset s_mix_channels "2"
18:42:57 : uset s_mix_depth "16"
18:42:57 : uset s_mix_rate "44100"
18:42:57 : uset s_sfx_enabled "1"
18:42:57 : uset s_music_enabled "1"
18:42:57 : uset s_sfx_volume "1.0"
18:42:57 : uset s_music_volume "1.0"
18:42:57 : uset s_reverse_stereo "0"
18:42:57 : uset s_device "ds8"
18:42:57 : uset r_vsync "1"
18:42:57 : uset r_quirks "0"
18:42:57 : uset r_anisotropy_factor "0.0"
18:42:57 : uset r_texture_detail "2"
18:42:57 : uset i_force_gain "1.0"
18:42:57 : uset i_feedback "1"
18:42:57 : uset i_joystick2 "-1"
18:42:57 : uset i_joystick1 "-1"
18:42:57 : uset i_deadzone "0.0"
18:42:57 : uset i_device "di8"
18:42:57 : uset m_invert "0"
18:42:57 : uset m_sensitivity "0.33"
18:42:57 : uset m_filter "0"
18:42:57 : uset g_view_dist "0.5"
18:42:57 : Euro Truck Simulator init ver.1.3 (rev. 24412)
18:42:57 : [gl] ICD OpenGL driver detected.
18:42:57 : [gl] driver: GeForce Go 7600/PCI/SSE2/3DNOW!
18:42:57 : [gl] vendor: NVIDIA Corporation
18:42:57 : [gl] version: 2.0.1
18:42:57 : [gl] GL extensions: GL_ARB_color_buffer_float GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_half_float_pixel GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_object GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_sRGB GL_EXT_timer_query GL_EXT_vertex_array GL_HP_occlusion_test GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
18:42:57 : [gl] GL_max_texture_size: 4096
18:42:57 : [gl] taking advantage of 'GL_ARB_multitexture'
18:42:57 : [gl] Sampler count: 4
18:42:57 : [gl] taking advantage of 'GL_ARB_fragment_program'
18:42:57 : [gl] taking advantage of 'GL_ARB_texture_mirrored_repeat'
18:42:57 : [gl] taking advantage of 'GL_ARB_texture_border_clamp'
18:42:57 : [gl] taking advantage of 'GL_ARB_texture_compression'
18:42:57 : [gl] taking advantage of 'GL_EXT_texture_compression_s3tc'
18:42:57 : [gl] taking advantage of 'GL_ARB_texture_cube_map'
18:42:57 : [gl] taking advantage of 'GL_ARB_texture_env_combine'
18:42:57 : [gl] taking advantage of 'GL_ARB_texture_rectangle'
18:42:57 : [gl] taking advantage of 'GL_ARB_transpose_matrix'
18:42:57 : [gl] taking advantage of 'GL_ARB_vertex_buffer_object'
18:42:57 : [gl] taking advantage of 'GL_ARB_vertex_program'
18:42:57 : [gl] Vertex attribute count: 16
18:42:57 : [gl] taking advantage of 'GL_ARB_shader_objects'
18:42:57 : [gl] taking advantage of 'GL_ARB_vertex_shader'
18:42:57 : [gl] taking advantage of 'GL_ARB_fragment_shader'
18:42:57 : [gl] taking advantage of 'GL_ATI_draw_buffers'
18:42:57 : [gl] taking advantage of 'GL_EXT_blend_color'
18:42:57 : [gl] taking advantage of 'GL_EXT_compiled_vertex_array'
18:42:57 : [gl] taking advantage of 'GL_EXT_draw_range_elements'
18:42:57 : [gl] taking advantage of 'GL_EXT_rescale_normal'
18:42:57 : [gl] taking advantage of 'GL_EXT_secondary_color'
18:42:57 : [gl] taking advantage of 'GL_EXT_separate_specular_color'
18:42:57 : [gl] taking advantage of 'GL_EXT_texture3D'
18:42:57 : [gl] taking advantage of 'GL_EXT_texture_edge_clamp'
18:42:57 : [gl] taking advantage of 'GL_EXT_texture_env_add'
18:42:57 : [gl] taking advantage of 'GL_EXT_texture_filter_anisotropic'
18:42:57 : [gl] Max anisotropy factor: 16
18:42:57 : [gl] taking advantage of 'GL_NV_register_combiners'
18:42:57 : [gl] taking advantage of 'GL_NV_register_combiners2'
18:42:57 : [gl] taking advantage of 'GL_NV_texture_env_combine4'
18:42:57 : [gl] taking advantage of 'GL_NV_texture_shader'
18:42:57 : [gl] taking advantage of 'GL_NV_texture_shader2'
18:42:57 : [gl] taking advantage of 'GL_NV_texture_shader3'
18:42:57 : [gl] taking advantage of 'GL_NV_fragment_program'
18:42:57 : [gl] taking advantage of 'GL_NV_fragment_program_option'
18:42:57 : [gl] taking advantage of 'GL_NV_fragment_program2'
18:42:57 : [gl] taking advantage of 'GL_NV_vertex_program'
18:42:57 : [gl] taking advantage of 'GL_NV_vertex_program2'
18:42:57 : [gl] taking advantage of 'GL_NV_vertex_program2_option'
18:42:57 : [gl] taking advantage of 'GL_NV_vertex_program3'
18:42:57 : [gl] taking advantage of 'GL_SGIS_generate_mipmap'
18:42:57 : [gl] taking advantage of 'WGL_ARB_extensions_string'
18:42:57 : [gl] WGL extensions: WGL_ARB_buffer_region WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_EXT_extensions_string WGL_EXT_swap_control WGL_NV_float_buffer WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle
18:42:57 : [gl] taking advantage of 'WGL_EXT_swap_control'
18:42:57 : [gl] taking advantage of 'WGL_ARB_pixel_format'
18:42:57 : [gl] taking advantage of 'WGL_ARB_pbuffer'
18:42:57 : [gl] taking advantage of 'WGL_ARB_render_texture'
18:42:57 : [gl] taking advantage of 'WGL_NV_render_texture_rectangle'
18:42:57 : [gl] taking advantage of 'GL_ARB_multisample'
18:43:00 : [gl] Detected support for 16x anti-aliasing.
18:43:00 : [gl] Detected support for 8x anti-aliasing.
18:43:00 : [gl] Detected support for 4x anti-aliasing.
18:43:01 : [gl] Detected support for 2x anti-aliasing.
18:43:01 : [gl-quirk] Enabling workaround for alpha-testing overoptimization.
18:43:01 : Rendering path available: GL1X
18:43:01 : Rendering path available: ARB1
18:43:01 : Rendering path available: NV1X
18:43:01 : Rendering path available: NV2X
18:43:01 : Rendering path available: NV3X
18:43:01 : Rendering path available: NV4X
18:43:01 : Rendering path available: ARB2
18:43:01 : Rendering path available: GL2X
18:43:01 : [dx9] Direct3D9 detected.
18:43:01 : [dx9] Number of adapters found: 1
18:43:01 : [dx9] Adapter #0: NVIDIA GeForce Go 7600 (nv4_disp.dll) [driver version: 6.14.10.8602]
18:43:01 : Rendering path available: SM2X
18:43:01 : Rendering path available: SM3X
18:43:01 : [gl] SetPixelFormat: OK (31, color 32 bits, depth 24 bits).
18:43:01 : [gl] wglCreateContext: OK
18:43:01 : [gl] OpenGL framebuffer context init OK
18:43:01 : [gfx] Created drawable (/procedural/dashboard.tobj)
18:43:01 : [gfx] Created drawable (/procedural/vehicle_env.tobj)
18:43:01 : [gfx] Created drawable (/procedural/generic_env.tobj)
18:43:01 : [gfx] Created drawable (/procedural/water_env.tobj)
18:43:01 : [snd] select device (ds8)
18:43:01 : [ds8] Available device : Первичный звуковой драйвер ().
18:43:01 : [ds8] Available device : Realtek HD Audio output (RtkHDAud.sys).
18:43:01 : [ds8] Initialization OK.
18:43:01 : g_ui_recache
18:43:01 : exit
18:43:03 : [Ode] Starting physics server: Open Dynamics Engine (svn revision 1119)
18:43:04 : Loading city data ....
18:43:04 : Loading country data ....
18:43:04 : Loading cargo data ....
18:43:13 : [fs] Unable to open file for reading. (/vehicle/truck/volvo/truck.Default Material.mat)
18:43:13 : [material] Can not open '/vehicle/truck/volvo/truck.Default Material.mat'
18:43:13 : [r_effect_man] Failed to create effect 'eut.L.fx'
18:43:13 : [material] Can not create effect 'eut.L.fx' - requested in material '/vehicle/truck/volvo/L.L.mat'.
18:43:13 : [fs] Unable to open file for reading. (/vehicle/truck/volvo/l.dds)
18:43:13 : [dds] Can not load '/vehicle/truck/volvo/l.dds'
18:43:13 : [fs] Unable to open file for reading. (/vehicle/truck/volvo/truck.dif_spec.add.env.tintadd.mat)
18:43:13 : [material] Can not open '/vehicle/truck/volvo/truck.dif_spec.add.env.tintadd.mat'
18:43:37 : game
18:43:38 : [Ode] Starting physics server: Open Dynamics Engine (svn revision 1119)
18:43:41 : Loading resource server data ....
18:43:41 : Loading road data ....
18:43:41 : Loading terrain data ....
18:43:41 : Loading railing data ....
18:43:41 : Loading building data ....
18:43:42 : Loading model data ....
18:43:43 : Loading prefab data ....
18:43:43 : Loading sign data ....
18:43:44 : Loading traffic lights data ....
18:43:44 : Loading vegetation data ....
18:43:44 : Loading hinges data ....
18:43:44 : Loading stamp data ....
18:43:44 : Loading movers data ....
18:43:44 : Loading animated models ....
18:43:44 : Loading ferries ....
18:43:44 : Loading city data ....
18:43:44 : Loading cargo data ....
18:43:44 : Loading company data ....
18:43:44 : Loading country data ....
18:43:52 : Map successfully loaded ....
18:43:53 : Starting the campaign ...
18:44:07 : ui t console:system_02
18:44:08 : ui t console:system_02
18:44:10 : ui t console:system_02
18:44:12 : ui t console:system_02
18:44:13 : ui t console:system_02
18:44:39 : screenshot
18:44:39 : Screenshot written: '/screenshot/ets_00014.png'.
18:44:42 : ui t console:system_02
18:44:46 : ui t console:system_02
18:44:47 : quit
18:44:47 : [gfx] Destroying drawable (/procedural/dashboard.tobj)
18:44:47 : [gfx] Destroying drawable (/procedural/water_env.tobj)
18:44:47 : [gfx] Destroying drawable (/procedural/generic_env.tobj)
18:44:47 : [gfx] Destroying drawable (/procedural/vehicle_env.tobj)
18:44:47 : [gl] Context shutdown
18:44:48 : [sys] process shutdown
народ спасайте как это править??? весь трак красный!!
23:29:47 : [fs] Unable to open file for reading. (/vehicle/truck/volvo/truck.Default Material.mat)
23:29:47 : [material] Can not open '/vehicle/truck/volvo/truck.Default Material.mat'
23:29:47 : [fs] Unable to open file for reading. (/vehicle/truck/volvo/L.L.mat)
23:29:47 : [material] Can not open '/vehicle/truck/volvo/L.L.mat'
23:29:47 : [fs] Unable to open file for reading. (/vehicle/truck/volvo/truck.dif_spec.add.env.tintadd.mat)
23:29:47 : [material] Can not open '/vehicle/truck/volvo/truck.dif_spec.add.env.tintadd.mat'
23:29:47 : [fs] Unable to open file for reading. (/vehicle/truck/f12/glass.dif_spec.add.env.mat)
23:29:47 : [material] Can not open '/vehicle/truck/f12/glass.dif_spec.add.env.mat'
23:29:47 : [fs] Unable to open file for reading. (/vehicle/truck/f12/bodybasic.dif_spec.add.env.mat)
23:29:47 : [material] Can not open '/vehicle/truck/f12/bodybasic.dif_spec.add.env.mat'
Отредактировано Winnerx (2011-06-20 23:35:35)
Winnerx нету матов у грузовика поэтому он красный
что нада зделать чтобы переставить машыну из скании с на место мерседеса а???
Отредактировано Pro100_ololol (2011-06-26 09:41:13)
Pro100_ololol написал(а):
Pro100_ololol
В место scania.rcab.c поменяй на
mercedes.actros.a
захожу
vehicle\truck\definition\scania_rcab_c.sii
меняю: scania.rcab.c на mercedes.actros.a не получается машына вообще исчезает
Pro100_ololol возми дефолный   mercedes_actros_а.sii
и на него перепеши свою сканию
Блин, скачал карту от Марио для 1.3, вылетает. У меня 1.3. Главное, что вылетает спустя от 10 сек до 2-х минут от начала игры.
Вот лог:
******** : log created on : Tuesday June 28 2011 @ 20:33:24
20:33:24 : [sys] running on x86 / Windows 7 (version 6.1) / Service Pack 2
20:33:24 : [sys] DirectX version : 4.09.00.0904
20:33:24 : [cpu] AuthenticAMD [AMD Athlon(tm) II X4 620 Processor] at ~2611MHz.
20:33:24 : [cpu] Features utilized: fpu cmov mmx mmxext 3dnow 3dnowext sse sse2.
20:33:24 : [sys] using QPC / unknown timer (thread affinity: 3), frequency 2550302Hz
20:33:24 : physical memory detected (2097151K/2097151K)
20:33:24 : virtual memory detected (2097024K/2034772K)
20:33:24 : Trying to allocate memory pool (409600K)
20:33:26 : [zipfs] base.scs: mounted ok, 9452 entries [crc_0x3de36445]
20:33:26 : [ufs] registered symlink from /custom_build/en_gb to /
20:33:26 : [zipfs] <mem-addr-file>: mounted ok, 11 entries [crc_0x32159817]
20:33:26 : [ufs] Home directory: 'D:/My Documents/Euro Truck Simulator'.
20:33:26 : Mounting extra package: D:/My Documents/Euro Truck Simulator/mod/aitrailermod.scs
20:33:27 : [zipfs] D:/My Documents/Euro Truck Simulator/mod/aitrailermod.scs: mounted ok, 114 entries [crc_0x6eb93485]
20:33:27 : Mounting extra package: D:/My Documents/Euro Truck Simulator/mod/Ayats Bravo II.scs
20:33:27 : [zipfs] D:/My Documents/Euro Truck Simulator/mod/Ayats Bravo II.scs: mounted ok, 35 entries [crc_0x7e451c1a]
20:33:27 : Mounting extra package: D:/My Documents/Euro Truck Simulator/mod/driver_by_MC_KING.scs
20:33:27 : [zipfs] D:/My Documents/Euro Truck Simulator/mod/driver_by_MC_KING.scs: mounted ok, 8 entries [crc_0x39bbc15d]
20:33:27 : Mounting extra package: D:/My Documents/Euro Truck Simulator/mod/ETS Xenon _ Poz.scs
20:33:27 : [zipfs] D:/My Documents/Euro Truck Simulator/mod/ETS Xenon _ Poz.scs: mounted ok, 4 entries [crc_0x814970b]
20:33:27 : Mounting extra package: D:/My Documents/Euro Truck Simulator/mod/ETS_ DAF XF105 Vanderveren.scs
20:33:27 : [zipfs] D:/My Documents/Euro Truck Simulator/mod/ETS_ DAF XF105 Vanderveren.scs: mounted ok, 780 entries [crc_0x7fc7f845]
20:33:27 : Mounting extra package: D:/My Documents/Euro Truck Simulator/mod/ETS_1.2_14.0.scs
20:33:41 : [zipfs] D:/My Documents/Euro Truck Simulator/mod/ETS_1.2_14.0.scs: mounted ok, 28752 entries [crc_0x8513cbc1]
20:33:41 : Mounting extra package: D:/My Documents/Euro Truck Simulator/mod/flarepack by Samson with one LED.scs
20:33:41 : [zipfs] D:/My Documents/Euro Truck Simulator/mod/flarepack by Samson with one LED.scs: mounted ok, 95 entries [crc_0x3abfa1e6]
20:33:41 : Mounting extra package: D:/My Documents/Euro Truck Simulator/mod/gtsdafinetrior_by_stalker45.scs
20:33:41 : [zipfs] D:/My Documents/Euro Truck Simulator/mod/gtsdafinetrior_by_stalker45.scs: mounted ok, 199 entries [crc_0xe9916d22]
20:33:41 : Mounting extra package: D:/My Documents/Euro Truck Simulator/mod/Krone Cool Liner.scs
20:33:41 : [zipfs] D:/My Documents/Euro Truck Simulator/mod/Krone Cool Liner.scs: mounted ok, 36 entries [crc_0x7b10ba46]
20:33:41 : Mounting extra package: D:/My Documents/Euro Truck Simulator/mod/MAGNUM_Interior_by_Sax.scs
20:33:41 : [zipfs] D:/My Documents/Euro Truck Simulator/mod/MAGNUM_Interior_by_Sax.scs: mounted ok, 24 entries [crc_0xe7fd8a89]
20:33:41 : Mounting extra package: D:/My Documents/Euro Truck Simulator/mod/mercedes_interior.scs
20:33:41 : [zipfs] D:/My Documents/Euro Truck Simulator/mod/mercedes_interior.scs: mounted ok, 62 entries [crc_0xbec0e1ed]
20:33:41 : Mounting extra package: D:/My Documents/Euro Truck Simulator/mod/OLS_steering_wheel_logos_compiled_by_reinhard.scs
20:33:41 : [zipfs] D:/My Documents/Euro Truck Simulator/mod/OLS_steering_wheel_logos_compiled_by_reinhard.scs: mounted ok, 30 entries [crc_0x6f767102]
20:33:41 : Mounting extra package: D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #5 - def/vehicle/sound/sound1-ext.sii from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #6 - def/vehicle/sound/sound1-int.sii from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #12 - sound/environment/click.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #13 - sound/environment/wiper_l_to_r_1.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #14 - sound/environment/wiper_r_to_l_1.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #17 - sound/truck/ext/high_02.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #18 - sound/truck/ext/high_03.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #19 - sound/truck/ext/high_04.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #20 - sound/truck/ext/horn1.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #21 - sound/truck/ext/horn2.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #22 - sound/truck/ext/horn4.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #23 - sound/truck/ext/idle_01.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #24 - sound/truck/ext/idle_02.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #25 - sound/truck/ext/idle_09.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #26 - sound/truck/ext/low_01.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #27 - sound/truck/ext/low_03b.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #28 - sound/truck/ext/mbrake10.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #29 - sound/truck/ext/mbrake8.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #30 - sound/truck/ext/mbrake9.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #31 - sound/truck/ext/start_1.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #32 - sound/truck/ext/start_2.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #33 - sound/truck/ext/start_4.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #34 - sound/truck/ext/stop_002.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #35 - sound/truck/ext/stop_01.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #36 - sound/truck/ext/stop_02.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #37 - sound/truck/ext/tick_3b.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #38 - sound/truck/ext/tick_5.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #39 - sound/truck/ext/tick_8b.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #41 - sound/truck/int/high_02.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #42 - sound/truck/int/high_03.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #43 - sound/truck/int/high_04.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #44 - sound/truck/int/horn1.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #45 - sound/truck/int/horn2.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #46 - sound/truck/int/horn4.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #47 - sound/truck/int/idle_01.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #48 - sound/truck/int/idle_02.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #49 - sound/truck/int/idle_09.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #50 - sound/truck/int/low_01.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #51 - sound/truck/int/low_03b.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #52 - sound/truck/int/mbrake10.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #53 - sound/truck/int/mbrake8.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #54 - sound/truck/int/mbrake9.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #55 - sound/truck/int/start_1.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #56 - sound/truck/int/start_2.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #57 - sound/truck/int/start_4.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #58 - sound/truck/int/stop_002.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #59 - sound/truck/int/stop_01.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #60 - sound/truck/int/stop_02.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #61 - sound/truck/int/tick_3b.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #62 - sound/truck/int/tick_5.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] Unsupported compression method used: 8 for record #63 - sound/truck/int/tick_8b.ogg from 'D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs'.
20:33:41 : [zipfs] D:/My Documents/Euro Truck Simulator/mod/renault_magnum_tuned_v1.5.scs: mounted ok, 168 entries [crc_0x5d20ba1a]
20:33:41 : Mounting extra package: D:/My Documents/Euro Truck Simulator/mod/Rusifikator.scs
20:33:41 : [zipfs] D:/My Documents/Euro Truck Simulator/mod/Rusifikator.scs: mounted ok, 23 entries [crc_0xfef37221]
20:33:41 : Mounting extra package: D:/My Documents/Euro Truck Simulator/mod/Schwarzmller Thermo 2009 by Kisbrekusz & RS.scs
20:33:42 : [zipfs] D:/My Documents/Euro Truck Simulator/mod/Schwarzmller Thermo 2009 by Kisbrekusz & RS.scs: mounted ok, 65 entries [crc_0x202372ec]
20:33:42 : Mounting extra package: D:/My Documents/Euro Truck Simulator/mod/vehicle_real_logos.scs
20:33:42 : [zipfs] D:/My Documents/Euro Truck Simulator/mod/vehicle_real_logos.scs: mounted ok, 20 entries [crc_0x497de314]
20:33:42 : exec /home/config.cfg
20:33:42 : [sys] Executing /home/config.cfg ...
20:33:42 : uset g_minicon "0"
20:33:42 : uset g_console "1"
20:33:42 : uset g_trackir "1"
20:33:42 : uset g_developer "1"
20:33:42 : uset g_save_idx "166"
20:33:42 : uset g_mouse_control "0"
20:33:42 : uset g_steering_func_param "0"
20:33:42 : uset g_joy_axis_brake_dz "0.0"
20:33:42 : uset g_joy_axis_brake "5"
20:33:42 : uset g_joy_ff_gain "1.0"
20:33:42 : uset g_joy_axis_throttle_dz "0.0"
20:33:42 : uset g_joy_axis_throttle "1"
20:33:42 : uset g_joy_axis_ff "1"
20:33:42 : uset g_joy_axis_combine "0"
20:33:42 : uset g_joy_axis_steer_sens "0"
20:33:42 : uset g_joy_axis_steer_dz "0"
20:33:42 : uset g_joy_axis_steer "0"
20:33:42 : uset g_tutorial "0"
20:33:42 : uset g_job_sort "2"
20:33:42 : uset g_gauges "0"
20:33:42 : uset g_mirrors "1"
20:33:42 : uset g_fatigue "1"
20:33:42 : uset g_police "0"
20:33:42 : uset g_subtitles "0"
20:33:42 : uset g_quality "2"
20:33:42 : uset g_reflection "1"
20:33:42 : uset g_atrans "1"
20:33:42 : uset g_flyspeed "100.0"
20:33:42 : uset g_lang "bg_bg"
20:33:42 : uset g_colbox "0"
20:33:42 : uset r_gamma "1.12"
20:33:42 : uset r_path "22"
20:33:42 : uset r_msaa "4"
20:33:42 : uset r_fullscreen "1"
20:33:42 : uset r_mode "1680x1050x32x60"
20:33:42 : uset r_device "dx9"
20:33:42 : uset r_driver "dx9"
20:33:42 : uset g_texture_usage_stats "0"
20:33:42 : uset g_fps "0"
20:33:42 : uset ds8_mix_channels "2"
20:33:42 : uset ds8_mix_depth "16"
20:33:42 : uset ds8_mix_rate "44100"
20:33:42 : uset ds8_reverse_stereo "0"
20:33:42 : uset s_acceleration "0"
20:33:42 : uset s_mix_channels "2"
20:33:42 : uset s_mix_depth "16"
20:33:42 : uset s_mix_rate "44100"
20:33:42 : uset s_sfx_enabled "1"
20:33:42 : uset s_music_enabled "1"
20:33:42 : uset s_sfx_volume "1.0"
20:33:42 : uset s_music_volume "0"
20:33:42 : uset s_reverse_stereo "0"
20:33:42 : uset s_device "ds8"
20:33:42 : uset r_vsync "1"
20:33:42 : uset r_quirks "0"
20:33:42 : uset r_anisotropy_factor "0.5"
20:33:42 : uset r_texture_detail "0"
20:33:42 : uset i_force_gain "1.0"
20:33:42 : uset i_feedback "1"
20:33:42 : uset i_joystick2 "-1"
20:33:42 : uset i_joystick1 "0"
20:33:42 : uset i_deadzone "0.0"
20:33:42 : uset i_device "di8"
20:33:42 : uset m_invert "0"
20:33:42 : uset m_sensitivity "0.33"
20:33:42 : uset m_filter "0"
20:33:42 : Euro Truck Simulator init ver.1.3 (rev. 24412)
20:33:42 : [r_effect] The effect name 'ui.fx' is not unique.
20:33:42 : [gl] ICD OpenGL driver detected.
20:33:42 : [gl] driver: ATI Radeon HD 5700 Series
20:33:42 : [gl] vendor: ATI Technologies Inc.
20:33:42 : [gl] version: 4.1.10750 Compatibility Profile Context
20:33:42 : [gl] GL extensions: GL_AMDX_debug_output GL_AMDX_vertex_shader_tessellator GL_AMD_conservative_depth GL_AMD_debug_output GL_AMD_depth_clamp_separate GL_AMD_draw_buffers_blend GL_AMD_multi_draw_indirect GL_AMD_name_gen_delete GL_AMD_performance_monitor GL_AMD_sample_positions GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_AMD_shader_trace GL_AMD_texture_cube_map_array GL_AMD_texture_texture4 GL_AMD_transform_feedback3_lines_triangles GL_AMD_vertex_shader_tessellator GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_color_buffer_float GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_indirect GL_ARB_draw_instanced GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_stencil_export GL_ARB_shader_subroutine GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_snorm GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_meminfo GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_buffer GL_EXT_copy_texture GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_histogram GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shader_image_load_store GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_bptc GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_explicit_multisample GL_NV_float_buffer GL_NV_half_float GL_NV_primitive_restart GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint WGL_EXT_swap_control
20:33:42 : [gl] GL_max_texture_size: 16384
20:33:42 : [gl] taking advantage of 'GL_ARB_multitexture'
20:33:42 : [gl] Sampler count: 8
20:33:42 : [gl] taking advantage of 'GL_ARB_fragment_program'
20:33:42 : [gl] taking advantage of 'GL_ARB_texture_mirrored_repeat'
20:33:42 : [gl] taking advantage of 'GL_ARB_texture_border_clamp'
20:33:42 : [gl] taking advantage of 'GL_ARB_texture_compression'
20:33:42 : [gl] taking advantage of 'GL_EXT_texture_compression_s3tc'
20:33:42 : [gl] taking advantage of 'GL_ARB_texture_cube_map'
20:33:42 : [gl] taking advantage of 'GL_ARB_texture_env_crossbar'
20:33:42 : [gl] taking advantage of 'GL_ARB_texture_env_combine'
20:33:42 : [gl] taking advantage of 'GL_ARB_texture_rectangle'
20:33:42 : [gl] taking advantage of 'GL_ARB_transpose_matrix'
20:33:42 : [gl] taking advantage of 'GL_ARB_vertex_buffer_object'
20:33:42 : [gl] taking advantage of 'GL_ARB_vertex_program'
20:33:42 : [gl] Vertex attribute count: 29
20:33:42 : [gl] The attribute count limit clamped down to 16 from 29.
20:33:42 : [gl] taking advantage of 'GL_ARB_shader_objects'
20:33:42 : [gl] taking advantage of 'GL_ARB_vertex_shader'
20:33:42 : [gl] taking advantage of 'GL_ARB_fragment_shader'
20:33:42 : [gl] taking advantage of 'GL_ATI_fragment_shader'
20:33:42 : [gl] taking advantage of 'GL_ATI_draw_buffers'
20:33:42 : [gl] taking advantage of 'GL_ATI_texture_env_combine3'
20:33:42 : [gl] taking advantage of 'GL_EXT_blend_color'
20:33:42 : [gl] taking advantage of 'GL_EXT_compiled_vertex_array'
20:33:42 : [gl] taking advantage of 'GL_EXT_draw_range_elements'
20:33:42 : [gl] taking advantage of 'GL_EXT_rescale_normal'
20:33:42 : [gl] taking advantage of 'GL_EXT_secondary_color'
20:33:42 : [gl] taking advantage of 'GL_EXT_separate_specular_color'
20:33:42 : [gl] taking advantage of 'GL_EXT_texture3D'
20:33:42 : [gl] taking advantage of 'GL_EXT_texture_edge_clamp'
20:33:42 : [gl] taking advantage of 'GL_EXT_texture_env_add'
20:33:42 : [gl] taking advantage of 'GL_EXT_texture_filter_anisotropic'
20:33:42 : [gl] Max anisotropy factor: 16
20:33:42 : [gl] taking advantage of 'GL_SGIS_generate_mipmap'
20:33:42 : [gl] taking advantage of 'WGL_ARB_extensions_string'
20:33:42 : [gl] WGL extensions: WGL_ARB_extensions_string WGL_ARB_pixel_format WGL_ATI_pixel_format_float WGL_ARB_pixel_format_float WGL_ARB_multisample WGL_EXT_swap_control WGL_ARB_pbuffer WGL_ARB_render_texture WGL_ARB_make_current_read WGL_EXT_extensions_string WGL_ARB_buffer_region WGL_EXT_framebuffer_sRGB WGL_ATI_render_texture_rectangle WGL_EXT_pixel_format_packed_float WGL_I3D_genlock WGL_NV_swap_group WGL_ARB_create_context WGL_AMD_gpu_association WGL_AMDX_gpu_association WGL_ARB_create_context_profile WGL_NV_float_buffer
20:33:42 : [gl] taking advantage of 'WGL_EXT_swap_control'
20:33:42 : [gl] taking advantage of 'WGL_ARB_pixel_format'
20:33:42 : [gl] taking advantage of 'WGL_ARB_pbuffer'
20:33:42 : [gl] taking advantage of 'WGL_ARB_render_texture'
20:33:42 : [gl] taking advantage of 'GL_ARB_multisample'
20:33:42 : [gl] Detected support for 8x anti-aliasing.
20:33:42 : [gl] Detected support for 4x anti-aliasing.
20:33:42 : [gl] Detected support for 2x anti-aliasing.
20:33:42 : [gl] Detected support for 1x anti-aliasing.
20:33:42 : Rendering path available: GL1X
20:33:42 : Rendering path available: ARB1
20:33:42 : Rendering path available: R2XX
20:33:42 : Rendering path available: ARB2
20:33:42 : Rendering path available: GL2X
20:33:42 : [dx9] Direct3D9Ex detected.
20:33:42 : [dx9] Number of adapters found: 1
20:33:42 : [dx9] Adapter #0: ATI Radeon HD 5700 Series  (aticfx32.dll) [driver version: 8.17.10.1077]
20:33:42 : Rendering path available: SM2X
20:33:42 : Rendering path available: SM3X
20:33:43 : [dx9] D3D9 device sucessfully created [HWVP]
20:33:43 : [gfx] Created drawable (/procedural/dashboard.tobj)
20:33:43 : [gfx] Created drawable (/procedural/vehicle_env.tobj)
20:33:43 : [gfx] Created drawable (/procedural/generic_env.tobj)
20:33:43 : [gfx] Created drawable (/procedural/water_env.tobj)
20:33:43 : [snd] select device (ds8)
20:33:43 : [ds8] Available device : Первичный звуковой драйвер ().
20:33:43 : [ds8] Available device : Динамики (VIA High Definition Audio) ({0.0.0.00000000}.{8ee280e8-a839-4bef-8fe3-b42b856407ec}).
20:33:43 : [ds8] Available device : SPDIF Interface (TX1) (VIA High Definition Audio) ({0.0.0.00000000}.{ec16c81c-f83d-4159-9721-f4731e3033a1}).
20:33:43 : [ds8] Available device : SPDIF Interface (TX0) (VIA High Definition Audio) ({0.0.0.00000000}.{f01c8597-9ee9-4ab0-b6a9-c3e4433ed1f8}).
20:33:43 : [ds8] Initialization OK.
20:33:43 : [di8] Joystick/GamePad device: \bLogitech MOMO Racing
20:33:43 : g_ui_recache
20:33:43 : exit
20:33:43 : [Ode] Starting physics server: Open Dynamics Engine (svn revision 1119)
20:33:43 : [fs] Unable to open file for reading. (/vehicle/truck/daf_cf/interior/cllight_st.pma)
20:33:43 : [ld] failed to open /vehicle/truck/daf_cf/interior/cllight_st.pma
20:33:43 : [fs] Unable to open file for reading. (/vehicle/truck/daf_cf/interior/farlight_st.pma)
20:33:43 : [ld] failed to open /vehicle/truck/daf_cf/interior/farlight_st.pma
20:33:43 : [fs] Unable to open file for reading. (/vehicle/truck/daf_cf/interior/wipers_st.pma)
20:33:43 : [ld] failed to open /vehicle/truck/daf_cf/interior/wipers_st.pma
20:33:43 : Loading city data ....
20:33:43 : Loading country data ....
20:33:43 : Loading cargo data ....
20:33:51 : game
20:33:51 : [Ode] Starting physics server: Open Dynamics Engine (svn revision 1119)
20:33:51 : [fs] Unable to open file for reading. (/vehicle/truck/daf_cf/interior/cllight_st.pma)
20:33:51 : [ld] failed to open /vehicle/truck/daf_cf/interior/cllight_st.pma
20:33:51 : [fs] Unable to open file for reading. (/vehicle/truck/daf_cf/interior/farlight_st.pma)
20:33:51 : [ld] failed to open /vehicle/truck/daf_cf/interior/farlight_st.pma
20:33:51 : [fs] Unable to open file for reading. (/vehicle/truck/daf_cf/interior/wipers_st.pma)
20:33:51 : [ld] failed to open /vehicle/truck/daf_cf/interior/wipers_st.pma
20:33:51 : [fs] Unable to open file for reading. (/vehicle/ai/fabia/parts.tobj)
20:33:51 : [tobj] Can not open '/vehicle/ai/fabia/parts.tobj'
20:33:51 : [mem] Caching of the resource '/vehicle/ai/fabia/parts.tobj' failed.
20:33:51 : [fs] Unable to open file for reading. (/vehicle/ai/golf/parts.tobj)
20:33:51 : [tobj] Can not open '/vehicle/ai/golf/parts.tobj'
20:33:51 : [mem] Caching of the resource '/vehicle/ai/golf/parts.tobj' failed.
20:33:51 : [fs] Unable to open file for reading. (/vehicle/ai/ford_transit/parts.tobj)
20:33:51 : [tobj] Can not open '/vehicle/ai/ford_transit/parts.tobj'
20:33:51 : [mem] Caching of the resource '/vehicle/ai/ford_transit/parts.tobj' failed.
20:33:51 : [fs] Unable to open file for reading. (/vehicle/ai/a3/parts.tobj)
20:33:51 : [tobj] Can not open '/vehicle/ai/a3/parts.tobj'
20:33:51 : [mem] Caching of the resource '/vehicle/ai/a3/parts.tobj' failed.
20:33:51 : Loading resource server data ....
20:33:51 : Loading road data ....
20:33:51 : Loading terrain data ....
20:33:51 : Loading railing data ....
20:33:51 : Loading building data ....
20:33:51 : Loading model data ....
20:33:51 : Loading prefab data ....
20:33:51 : Loading sign data ....
20:33:51 : Loading traffic lights data ....
20:33:51 : Loading vegetation data ....
20:33:51 : Loading hinges data ....
20:33:51 : Loading stamp data ....
20:33:51 : Loading movers data ....
20:33:51 : Loading animated models ....
20:33:51 : Loading ferries ....
20:33:51 : Loading city data ....
20:33:51 : Loading cargo data ....
20:33:51 : Loading company data ....
20:33:51 : Loading country data ....
20:34:07 : Map successfully loaded ....
20:34:08 : Starting the saved game (/home/save/4) ...
20:34:11 : [projected_decal_builder_t::operator()] Decal index overflow!
20:34:51 : Log message token is currupted!($MONEY$)
20:35:12 : [fs] Unable to open file for reading. (/vehicle/ai/a3/parts.tobj)
20:35:12 : [tobj] Can not open '/vehicle/ai/a3/parts.tobj'
Кажется понял, не может открыть трафф ауди, у меня стоит мод на реал эмблемы.
Блин, не помогло, все-равно вылетает
Теперь в логе пишет, что не может открыть траффовый форд транзит :'(
А-фигня вся эта карта, даже с чистой папкой мод (с картой и только)-вылетает!!! :mad:
Может из-за ОпенАЛ и всякой этой фигни, надо попробовать поменять ОпенАЛ на директх, да только, как вернуть то окно перед запуском игры?
Теперь в логе
20:55:56 : [sys] process shutdown
Отредактировано demihra (2011-06-28 21:00:08)
Кто нибудь может мне дать пожалуйсто ссылку на инфу как создавать свои скины для тягачей и прицепов ? Заранее спасибо!
demihra
из мода удали папку  ai
эта папка с трафиком  из за неё вылеты
Отредактировано ARIO (2011-06-28 22:32:18)
у меня проблемка я играю в етс 1.3 поставил желтый камаз 5460 из дальнобойщиков 2 захожу в магазин хочу купить сначала грузиться потом вылет. в чем может быть проблемма ? только прицеп желтый нормально работает , жалко что грузовик не пашет а так хотел погонять :'(
Отредактировано alex2017 (2011-06-29 23:58:48)
