241
Парни в чём тут проблема я установил патч 1.02 и вроде всё работает но как прописываю худ к ивеке игра при загрузке вылетает:
22:19:24 : Loading stamp data ....
22:19:24 : Loading movers data ....
22:19:24 : Loading animated models ....
22:19:24 : Loading sound item data ....
22:19:24 : Loading cargo data ....
22:19:24 : Loading company data ....
22:19:24 : Loading city data ....
22:19:24 : Loading cargo descriptions ....
22:19:24 : Map '/map/germany.mbd' loading started ....
22:19:24 : Map successfully loaded ....
22:19:25 : [unit] File '/save/1/game.sii':
22:19:25 : [unit] The unit '_nameless.2379.C550' of type 'vehicle' has dangling pointer (to 'vehicle.iveco.stralis.a') in the attribute named 'permanent_vehicle_data'.
22:19:25 : [unit] The unit '_nameless.2379.C5C8' of type 'vehicle' has dangling pointer (to 'vehicle.scania.rcab.c') in the attribute named 'permanent_vehicle_data'.
22:19:25 : [unit] The unit '_nameless.2379.C640' of type 'vehicle' has dangling pointer (to 'vehicle.volvo.fh16.b') in the attribute named 'permanent_vehicle_data'.
22:19:25 : [unit] The unit '_nameless.2379.C6B8' of type 'vehicle' has dangling pointer (to 'vehicle.scania.rcab.c') in the attribute named 'permanent_vehicle_data'.
22:19:25 : [unit] The unit '_nameless.2379.C730' of type 'vehicle' has dangling pointer (to 'vehicle.man.tgx.c') in the attribute named 'permanent_vehicle_data'.
22:19:25 : [unit] The unit '_nameless.2379.C7A8' of type 'vehicle' has dangling pointer (to 'vehicle.scania.rcab.c') in the attribute named 'permanent_vehicle_data'.
22:19:25 : [unit] The unit '_nameless.2379.C820' of type 'vehicle' has dangling pointer (to 'vehicle.mercedes.actros.c') in the attribute named 'permanent_vehicle_data'.
22:19:25 : [unit] The pointer to 'vehicle.iveco.stralis.a' looks like dangling pointer.
22:19:25 : [unit] The pointer to 'vehicle.scania.rcab.c' looks like dangling pointer.
22:19:25 : [unit] The pointer to 'vehicle.volvo.fh16.b' looks like dangling pointer.
22:19:25 : [unit] The pointer to 'vehicle.man.tgx.c' looks like dangling pointer.
22:19:25 : [unit] The pointer to 'vehicle.mercedes.actros.c' looks like dangling pointer.
22:19:25 : load_unit_tree() - Failed to load unit tree from file (/home/save/1/game.sii)
22:19:25 : .\management\game_ctrl.cpp(613): ?create_economy@game_ctrl_u@prism@@IAEXABVstring@2@@Z: Unable to create economy unit!
free_vip написал(а):
Вобщем никак не хочет работать обратная связь в GTS. В ETS работала без проблем, а тут ни в какую. Ессно, в настройках все включено. Руль Thrustmaster RGT clutch. Драйвера последние. Погуглив на данную тему, видел, что у людей подобная проблема есть, но решения так и нету. Что посоветуете?
Проблема решилась установкой 1.02 патча. =))
Не пинайте сильно,но как отключить полицию?
Estranger
не пинаем :D , в confing.cfg  uset g_police "1" смени на uset g_police "0" ;)
Всем привет!!! Столкнулся с такой проблемой: привожу груз деньги +, а привозят водилы, деньги за работу идут не в + к общей сумме , а в -, Подскажите что это может быть и как это исправить? Сначала грешил на моды, но удалил всё под чистую, эффект остался тот же!!!
Отредактировано Defakto (2010-01-28 20:58:36)
установил патч и вот такая фишка у меня
http://s003.radikal.ru/i204/1001/15/fb4813bcf448t.jpg
как это исправить?
Было про это уже...переконвертить тга в ддс текстуру ну и в тобже поменять наверно
Lexan самое интересное ща патч снес и все нормально
у меня вот тоже было пару модов изза которых игра вылетала... снес игру к е*еням - и теперь все отлично, никаких проблем...  :rofl:
счас че-то комп подтормаживать стал... думаю вынести его с балкона 8го этажа - тормоза как рукой снимет ЛОЛ  :rofl:
Добавил в грузовик дамми на дым из трубы и грузовик стал весь зелёный и стёкла не прозрачные, почему так стало, кто-то может подсказать. Дамми брал с другого грузовика.
http://s003.radikal.ru/i204/1001/52/3d98e512c9bbt.jpg
Отредактировано selonik (2010-01-28 17:31:25)
Подскажите, как увеличить количество трафика на дорогах? Что и где изменить надо?
Спс.
SeregaS
никак! это уже миллион раз говорилось,обсуждалось и писалось! :angry:
в следующий раз,перед тем как зададть глупый вопрос почитай предыдущие сообщения в теме! :mad:
У меня такой вопрос - как можно сделать более частыми туман и дожди, ливни?
аналогично. уже кучу бабок сняли. в чем дело,ребята!? выручайте((
Спокойно чувак, не волнуйся так. Мог бы не отвечать.
SeregaS
Админы тебе бы еще жестче ответили! :yep:
текстуры слетели - когда импортировал все текстуры были на месте? пмд от занозы можно попробывать не ставить..
Подскажите пожалуйста как проделать такую операцию:
Есть трак он заменяет MAN С класса а я хочу поставить его на RENO B класса опишите пожалуйста по подробней как это сделать :writing:
Я понял, по привычке как в педалях сохранял, а тут как выясняется нужно ещё было при сохранении и текстуры прописать. Вот теперь не могу разобраться, текстуры прописал по новой, всё вроде стало на место, кроме стекла, то оно блестит как хром, то тёмное, хотя указываю текстуру glass, и в занозе всё видно, стало на место а в игре сбой.
В тебе модерские задатки проснулись? Одна мессага Шокку и твои дни сочтены :D
AK-74, загляни сюда ;) Только аккуратней, смотри чтобы вблизи компа никто не находился, все ж о тебе наверняка хорошего мнения :D
Отредактировано Yarik (2010-01-28 22:45:47)
Привет всем! Ребята, подскажите где находятся эти строки  trailer_storage.sii
хочу прицепы добавить...
Рыжий
это не строки а sii файл находится он vehicle\trailer_eu здесь, править блокнотом ;)
А что, норм. Суровый грузовик. Можно сверху ставить пушку (или еше чего-нить) и в бой  :D
http://www.profimages.com/photos/big/0025000/025551_294.jpg
Отредактировано free_vip (2010-01-28 23:42:24)
вот не могу найти этот файл vehicle\trailer_eu
и еще, накидал в папку mod грузовиков, теперь свет, что дальний, что ближний, стал какой-то синий... o.O
подскажите, как вернуть нормальные фары на машину....
тут вообще структура отличная от ПТТМ, начиная с конвоя и по сей день..все материалы прописываются в pmd файле, соотв править надо его...
Рыжий, убери мод на ксенон, и будет тебе счастье... :crazy:
Yarik написал(а):
AK-74, загляни сюда  Только аккуратней, смотри чтобы вблизи компа никто не находился, все ж о тебе наверняка хорошего мнения
Хорошо написал,  :rofl:  :rofl:
Извиняюсь за оффтоп, :D
Ну так че - никто не знает, как сделать более частыми туман и ливни в игре? о_О
Нет, это народными методами исправить к сожалению нельзя, только разрабы смогут. Или как есть, или постоянный дождь можно сделать.
народ подскажите ставлю пак прицепов BY TIRCI DORSE PACK....там почему та не рабочие фары...но не только у него....ставил грузовики тоже не работаю ....подскажите ?
